diyAudio Sponsor
Old 4th October 2006, 03:07 AM   #1
jarthel is offline jarthel  Australia
Default gary pimm's latest self-biasing CCS circuit
here's the page: http://home.pacifier.com/~gpimm/self_bias.htm.
here's the schematic: http://home.pacifier.com/~gpimm/self_bias_ccs.gif
1. It talks about "reference voltage" and it is ranging from 9.5 to 27V. Is this reference voltage the voltage across C2?
2. Is the output coming out the "-" lead (after R1)? I have a feeling this is right but just want to confirm.
thanks for the help
Old 4th October 2006, 11:20 PM   #2
leadbelly's Avatar
Default Re: gary pimm's latest self-biasing CCS circuit
I believe so.
Gary's CCS's are all "two-wire", which he confirmed to me in an email. So the output depends upon the application. If you're using the CCS for a plate load, then "-" is the output to the plate. If you're using the CCS for a long tailed pair, the "+" is the output to the cathodes.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 4th October 2006, 11:55 PM   #3
thanks for the help.
another question if you don't mind. how do I test the circuit (using it as a plate load) if I don't have a B+ supply.
in Bas Horneman's site (http://home.zonnet.nl/horneman/mosfet.htm), I can connect a 9V battery and a 10ohm resistor to check the circuit. But I believe the CCS is Bas' site is an older version.
I somehow have a feeling that this might not be possible with the latest circuit.
Old 5th October 2006, 12:03 AM   #4
leadbelly's Avatar
9V sounds low, but if you string a few in series you should be OK.
Old 5th October 2006, 12:05 AM   #5
same testing circuit as this http://home.zonnet.nl/horneman/image...urrent_set.gif
except that I have more than 9V? thanks again
Old 5th October 2006, 12:07 AM   #6
Send a message via AIM to Rescue Toaster
Depending on where you put R1 and how much current you're going for, the CCS will start to operate around 25-35v, though for large R1 & large R11 values, it can take more.
I assume your current is pretty low? Six 9v batteries in series should work. They won't last very long at 20-30ma for instance but you should be able to check that its working and trim the current.
Old 5th October 2006, 12:07 AM   #7
leadbelly's Avatar
Yes.
Old 5th October 2006, 12:09 AM   #8
I need 75mA. hmm maybe I do need a b+?
thanks again
Old 5th October 2006, 12:28 AM   #9
What R1 value did you choose?
Regardless, 6x 9v should cause it to turn on even with very large values of R1. Even good alkalines won't give you very long to test it though, so get it setup w/ your voltmeter across R1 already, and switch on. If you have to adjust R11 to an extreme to get it to 75ma, you probably need to change R10. Or you might have picked too large a value for R1.
vvv Sounds good. Unless you get unlucky with your mosfets you shouldn't have much trouble. You might be able to use only four 9v's to test but that gives pretty low Vds for Q2.
Old 5th October 2006, 12:36 AM   #10
200ohms
Gary Pimm's self biasing CCS - parts jkeny Solid State 5 18th May 2008 05:01 AM
is Gary Pimm still around? Nanook Tubes / Valves 9 17th June 2007 09:15 PM
Gary Pimm website? SunRa Tubes / Valves 8 29th January 2007 06:06 PM
Gary Pimm Jaime Tubes / Valves 0 24th January 2007 11:03 PM
how to set current in G Pimm's latest self-biasing CCS circuit? jarthel Tubes / Valves 0 31st October 2006 11:36 PM
Page generated in 0.10665 seconds (80.43% PHP - 19.57% MySQL) with 10 queries
