How to get more juice out of this shunt regulator
Old 2nd October 2006, 10:38 AM   #1
The Doogster is offline The Doogster  Australia
Default How to get more juice out of this shunt regulator
Hi chaps
I've breadboarded this shunt regulator. I want to use it to power an active crossover that needs 60mA per channel. So far it works fine to deliver 20mA, but when I use it for higher currents it doesn't work. I'm obviously pretty clueless about how regulators work, so can anyone tell me exactly what I need to do to increase its current capability?
Cheers. Doug
Old 2nd October 2006, 01:52 PM   #2
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
When you say "it doesn't work", what does it do? I think your 2k7 resistor is too high to deliver 60mA. Try 1k and see if it works. (If your problem is the TL431 and associated network, then I can't help because I don't know the device.)
Old 2nd October 2006, 02:06 PM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Agree. There's about 130V spare across that 2.7k. 60 mA takes away all of it and more. Ohms law. Lower it to 1k as suggested. Hopefully your transgformer & rectifier & filter can accomodate the (2 x) 60mA, if they drop then your 1k is still too high.
Jan Didden
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
How to get more juice out of this shunt regulatorHide this!Advertise here!
How about shunt regulatorH uhcmos Solid State 4 2nd March 2007 10:32 AM
Shunt regulator tubee Tubes / Valves 12 2nd March 2006 02:08 PM
