Noise floor rise on heathkit W4-AMs when power supply transformers were swapped
Old 2nd October 2006, 03:54 AM   #1
terminatorx is offline terminatorx  Canada
Default Noise floor rise on heathkit W4-AMs when power supply transformers were swapped
Hi. I just replaced the original power supply transformers on my Heathkit W4-AM williamson type amplifer. Since I've swapped the tranformers, the amplifiers have very noticeable increase in the noise floor (of varing levels sometimes nearly inaudable, sometimes loud enough to clearly hear when Im listening to music). I have not put a scope on the output, but I am suspecting it may be 60 Hz. The transformer I used was a Hammond 374BX.
My question is this. Could this new transformer be coupling into the signal stage of the amp? If yes, will it help if I rotate the transformer by 90 degrees? Anyother ideas?
Thanks,
Noah
Old 2nd October 2006, 03:35 PM   #2
bear is offline bear
expert in tautology
bear's Avatar
Is the orientation of the xfmr the same as the stock?
The secondary voltage(s) the same? <--?
Did you do this on only one amp, or do you have the same effect on two?
Try swapping the phase of the B+ secondary first.
I presume you are hearing LF hum, or is it a buzz?
It is possible that the old electrolytic simply decided to become leaky.
Add capacitance, or replace via jumpers to test that theory.
Scope on the B+ line will tell you much.
If all that fails, try physically lifting the new xfrmr - electrically insulating - at least temporarilly from the chassis, to see if there is leakage causing hum.
That's a two chassis amp, right? Power supply and main amp chassis?
Could also be a bad solder joint where they plug together... since you say it varies. Try a ground jumper between chassis just in case.
And, of course, did you wire it properly??
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 2nd October 2006, 10:16 PM   #3
Bear. Thx for the tips. Ill try some of them out. See my responses in line below....
-Its different.
-yes they are
-swapped both transformers, both amps are noisy now.
-I would say its more of a buzz
-yes two monblocks. Power supply and amp on both chasis.
Noah
Old 7th October 2006, 09:37 PM   #4
expert in tautology
bear's Avatar
Also if that all fails, try lifting (with the unit OFF and unplugged) the power transformers electrically off the chassis. The assumption here is AC leakage to ground.
Look around for a ground wire that is changed, moved or otherwise not connected, or a component that formerly was present or connected to ground...
_-_-bear
_-_-bear
Old 8th October 2006, 01:31 AM   #5
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Could it be that the old tranny had an electrostatic shield but the new one does not?
Noise floor rise on heathkit W4-AMs when power supply transformers were swappedHide this!Advertise here!
CS4272 noise floor problem 2sb18 Digital Source 1 1st October 2007 08:52 PM
Power supply for Heathkit ghola Tubes / Valves 1 17th May 2007 05:28 PM
Power supply for Heathkit WA-P2 pre-amplifier ghola Tubes / Valves 4 29th December 2006 02:04 PM
noise floor w/ and w/o input signal gearheadgene Class D 18 6th September 2006 08:04 AM
noise floor problem johndiy Solid State 12 31st August 2006 01:32 AM
