| diyAudio Sponsor | ||
Can anyone suggest any dual power triodes which are suitable for use in audio (other than the 6080 family which I have already used).
Thanks Shoog |
#2 |
You may include the 6528 with the 6080, but it's a bigger beast. Going the other way there's the 6BX7 which sounds pretty nice in outputs at lower power. I'm sure you know about all the dissimilar triodes like 6EM7, which only have one beefy section.
#3 |
Why not try something a little different like a Cossor 220B/240B.
#4 |
if you get Valve Amplifiers 3rd edition, there is a pushpull amp using 6528s in there.
wonderful design, and expertly engineered |
#5 |
Although Morgan Jones is all in favour of Push Pull amplifiers, he used the 6528 to build his scrapbox challenge: a SE design.
Erik |
#6 |
The 6528 looks interesting - but no more linear than the 6080's. I also don't really need any extra power. Also the input capacitance and medium Mu present problems for my prefered interstage transformer phase splitting.
The 220B and 240B look funky and interesting. Shoog |
#7 |
you're right on the valves, the pp design was using the 13e1s
#8 |
Is the 6AS7G normally included in the 6080-family? Otherwise that might be a suggestion.
#9 |
How about the 5998. Looks slightly more linear than the 6080 and also has higher mu so should be easier to drag a bit more power out of it. Otherwise its very similar.
Shoog |
#10 |
Hi Shoog,
There is always the 6N7. A small class B push pull tube. It will operate with zero grid bias (says the manual). The 6AS7G is lumped in with the 6080 family. Rather tightly I might add. -Chris |
| How to bias DH dual triodes? | leadbelly | Tubes / Valves | 13 | 24th February 2009 12:12 PM |
| Running stereo through a single tube with dual triodes? | RockysDad | Tubes / Valves | 2 | 21st January 2009 01:47 AM |
| Why not so common to split dual triodes between channels? | leadbelly | Tubes / Valves | 8 | 7th April 2007 01:42 AM |
| Substituting dual triodes | Carlp | Tubes / Valves | 13 | 10th June 2006 12:29 PM |
| Page generated in 0.10701 seconds (72.53% PHP - 27.47% MySQL) with 10 queries |
