| diyAudio Sponsor | ||
#21 |
Caution : The 6360 do not like at all the TRIODE MODE @ more than 150v !!!!!! In tetrode, it's great (with OA2 screen regulation)
#22 |
Coresta,
Your comments surprise me as I have graphed the tube as a triode beyond 350v with no proiblems whatsoever........ I referred to Telefunken figures before - as a tetrode the tube has G2 limitation of 200v - excess of your statement - and this figure is as a tetrode. Like many tubes this figure can be exceeded in the triode-connection. Please explain more where your stated limitation is derived from. If you read Telefunken figures, there is data where a single tube is utilised in AB1 modulator configuration - both with and without grid-current occuring. This tube is not a pussy - but I would hesitate to touch the glass under operation.....Each anode/plate is specced at 10.8 watts.....that's a horrible figure for the glass-size. Telefunken-specs, which I accept, reveal that the Mugig2 is 7.5, which is highly relevant for a triode application........ Happy to share graphed responses as a triode - pencilled on graph-paper - so they do not scan well.......better forwarded by e-mail if you seek. Graeme |
#23 |
Tom,
E-Mail me - happy to respond. Graeme |
#24 |
Graeme,
I 've done a try at triode mode with NOS Philips ones : One plate on each tube became red before the other one even at 30mA each tube ! tetrode mode is very simple for less problems of overdissipating . imho !Pierre |
#25 |
I have a pair of 6A6 dual triodes . I can't find any data on this.
Is this a low power triode and can this be used in a preamp ? Anyone know how this tube sounds ? I couldn't find any data sheets using google . Maybe I should try again. Cheers.
AM |
#26 |
diyAudio Moderator Emeritus
6A6 seems similar to 6N7, except for its UX-7 pin base. It's designed as a Class B amplifier, capable of 10w output into (I think) 8k p-p load. Frank Phillipse's site has 3 data sheets for 6A6.
#27 |
| How to bias DH dual triodes? | leadbelly | Tubes / Valves | 13 | 24th February 2009 11:12 AM |
| Running stereo through a single tube with dual triodes? | RockysDad | Tubes / Valves | 2 | 21st January 2009 12:47 AM |
| Why not so common to split dual triodes between channels? | leadbelly | Tubes / Valves | 8 | 7th April 2007 12:42 AM |
| Substituting dual triodes | Carlp | Tubes / Valves | 13 | 10th June 2006 11:29 AM |
| Page generated in 0.09554 seconds (76.64% PHP - 23.36% MySQL) with 10 queries |
