diyAudio Sponsor
Old 1st October 2006, 08:35 PM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Feedback basics
Since when I touched a little bit some feedbacks I got an attack on my personality let me touch it deeper snd explain some feedback basics.
Feedback means some part of a signal from output of a device is applied to the input of the same device. Negative feedback means to subtract some part of output signal from the input signal, positive feedback means some part of output signal is added to the input signal.
Negative feedback decreases a total gain of a device, while positive feedback increases it.
Why to decrease a gain?
A first, all known active elements such as vacuum tubes and transistors are not absolutely linear, they distort signals they amplify. A negative feedback makes an amplifier more linear; subtracting distortions made by amplifier itself. The overall linearity of such amplifier is better, and its frequency response is better, which means its gain is more equal on a broader band of frequencies.
We may take for a feedback both output current and output voltage, and apply to both in parallel and in series with input signal. It gives us a great flexibility to increase or decrease output resistance (impedance), to increase and decrease input resistance.
The picture shows several types of a negative feedback (for simplicity purposes I used transistors):
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 2nd October 2006, 04:38 PM   #2
bear's Avatar
Just curious, by what mechanism is the input resistance changed?
By how much?
_-_-bear
_-_-bear
http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! --
Old 2nd October 2006, 04:48 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
By how much?
_-_-bear
Easy. In the last pic, you will see that any rise in input voltage (at the base) will, through the feedback, give an almost equal rise in emitter voltage.
Because the emitter voltage follows the base voltage, there is no change in input current as a result of the voltage rise at the base (the Vb-e remains the same, almost).
According to ohms law, input resistance is (delta) input voltage divided by (delta) input current.
No change in current with change in voltage means infinite resistance.
Jan Didden
Old 2nd October 2006, 05:59 PM   #4
Claude Abraham's Avatar
Default re: feedback basics
The input resistance presented to the input source driving the base is:
Rb + ((beta + 1) * Re).
If no base resistor is present, then Rb becomes rbb', the internal base spreading resistance. As an example, if Rb = 0, rbb' = 10 ohms, beta = 100, and emitter resistance Re = 50 ohms, then Rin = 5,060 ohms.
In order for the circuit to present infinite input resistance, the transistor forward current gain, beta, would have to be infinite, OR, Re would have to be infinite. With real world finite values, the input resistance is always finite.
Have I answered the question(s)? BR.
"We wish to reach the moon, not because it is easy, but because it is hard."
John F. Kennedy, 1917-1963, US President
Old 2nd October 2006, 06:41 PM   #5
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Default Re: Feedback basics
Originally posted by Wavebourn
[BThe picture shows several types of a negative feedback (for simplicity purposes I used transistors):
[/B]
You shouldn't, we're in the "Tube" forum
Old 2nd October 2006, 06:48 PM   #6
diyAudio Moderator Emeritus
If the base resistance is 5060ohm (this range), where does the "negative base impedance" coming from?
It is usually cured by base stoppers about 100-220ohm. 220ohm is small compared to 5060ohm?
What is really happening in the case of "negative base impedance"? Why is base/grid stoppers are needed?
Old 2nd October 2006, 07:11 PM   #7
http://www.diyaudio.com/forums/showt...311#post424311
The above thread discussed this issue, and my answer is included. Basically, the negative resistance appears due to the emitter impedance, Ze, being reactive as well as resistive, and the forward current gain, beta or "hfe", being complex, not pure real. The product of two complex numbers, can contain a negative real part (resistance) even if both resistances are positive. I hope this helps.
Old 2nd October 2006, 07:25 PM   #8
janneman's Avatar
Default Re: re: feedback basics
I think he wanted to know what the feedback did to Zin. That is what I tried to explain in understandable terms. I may or may not have succeeded...
Jan Didden
Old 2nd October 2006, 07:39 PM   #9
Hi, Claude
Thanks for the explenation Make things alot clearer for me.
I got 3 questions :
1.Is there any other way to deal with this besides base stoppers? You said Re cannot help.
2.Is this only happens with EF? Why is that? Common emittor doesn't experience this?
3.Why I never see C in the attachment below? Inductor in place of base stoppers resistor?never see C in the attachment below? Inductor in place of base stoppers resistor?
Old 2nd October 2006, 08:19 PM   #10
janneman's Avatar
Hi, Claude
I got 3 questions :
But, David, you see the C often, its the miller comp cap!
And sometimes you see the inductor in the form of a bead.
Jan Didden
Help with the basics keantoken Everything Else 3 29th September 2006 02:04 AM
Need to learn the basics ChaseMe Subwoofers 4 14th July 2005 02:18 PM
ESL basics Urban Planars & Exotics 4 6th June 2005 06:11 PM
Help with crossover basics drfrink24 Multi-Way 2 28th December 2004 01:13 AM
DAC basics? Schaef Digital Source 17 7th June 2004 07:00 PM
Page generated in 0.12556 seconds (83.66% PHP - 16.34% MySQL) with 11 queries
