diyAudio Sponsor
Old 8th October 2006, 12:23 PM   #31
Following:
Old 8th October 2006, 12:34 PM   #32
Sorry; I should perhaps mention:
The results were not influenced by a significant change in loop gain as a result of changes in the T3-stage to give the different Rdrives. That was adjusted. The global NFB of about 27dB was maintained.
Old 8th October 2006, 05:57 PM   #33
smoking-amp's Avatar
Hello Johan,
Interesting graphs. Are these from a real speaker load or a fixed resistor load?
On the idea of displaying increasing higher harmonic distortion (although lower THD) with increasing NFB, it has been commented somewhere that as the device characteristic curvature is straightened out by increasing NFB, it is described by a power law math. model with power coefficient dropping toward unity but never quite getting there.
A coefficient of say 1.1 being the same as the fraction 11/10, this being equivalent to the 10th root of the 11th power, so no real surprise that higher harmonics are generated.
I recall an article in EW+WW a few years back where it was proposed to build an amplifier using square law Mosfets which would only generate 2nd harmonics, then they cancelled the 2nd harmonics with a push-pull design. Of course, real Mosfets aren't quite perfect square law unfortunately.
regards,
Don
Ohms Law V = I R
Old 8th October 2006, 09:50 PM   #34
Don,
Resistor load - these are actually Spice graphs, because I could load the graphics here more easily. But I did check with a simulated loudspeaker load - no mentionable difference. The load was not severe - 8 ohm system going to 16 ohm main resonance and down to 6 ohm; phase shift staying between +/- 15 degrees (equalised). Actual amplifier tests with spectrum analyser into resistive load showed confirmation, but I could not photograph those.
Your further explanation makes sense. Mathematics (a series) confirm that NFB increases high order harmonic products, e.g 3rd generated from 3rd, etc. I did not do such analysis, but it would seem that such products remain very low in amplitude, mostly in noise floor. It would appear to be harmonic multiplication but at very low amplitude. Products can go on over 100KHz, but at negligible amplitude, and so will any intermodulation products also be. This is of course only the case if the open-loop design itself is relatively clean to begin with - old principle.
.... and yes, unfortunately real life products are never that obliging!
Help with the basics keantoken Everything Else 3 29th September 2006 01:04 AM
Need to learn the basics ChaseMe Subwoofers 4 14th July 2005 01:18 PM
ESL basics Urban Planars & Exotics 4 6th June 2005 05:11 PM
Help with crossover basics drfrink24 Multi-Way 2 28th December 2004 12:13 AM
DAC basics? Schaef Digital Source 17 7th June 2004 06:00 PM
Page generated in 0.07992 seconds (73.51% PHP - 26.49% MySQL) with 11 queries
