diyAudio Sponsor
Old 19th April 2007, 09:41 PM   #61
trifidmaster's Avatar
Update:
After applying feedback, the max amplification became not enough.
Originally the preamp and the splitter were in 2 separate envelopes/channel.
Now, in the 2nd topology the the preamp + splitter are moved into one envelope. Doing so, one full tube (6922) became free/per channel. And as a next step this free tube was used as extra preamp + current source, and the amplifiaction is now more than enough.
Playing with the feedback (feedback resistor value + feedback topology) the sound starts to be "acceptable" with many different music including classical music.
The BEAUTIFUL sound of the 6922 is audible.
Stefan.
Old 2nd January 2008, 10:29 AM   #62
And finally the speakers are ready for the amp.
The sound is very "impressive". The speakers are in closed box, and still bass comes out from them. Highly recommended!
trif.
Old 2nd January 2008, 10:38 AM   #63
Here is the enclosure design - currently in "production"
trif.
Old 21st December 2008, 12:50 PM   #64
This projects start to live again - After many months I have decided: the current FE127E single drivers are NOT enough for my room/needs.
I am thinking into direction of using the FE207E from Fostex.
As soon as the speakers are built - new set of test will start. I hope that my "simple" PP will be able to drive these bigger speaker.
trif.
Laszlo's Valve Output Stage with Lundahl transformer oshifis Digital Source 21 4th October 2010 12:12 PM
6SN7 operating points input gain stage and concertina DrewP Tubes / Valves 13 14th July 2009 11:03 PM
Possible group buy of Lundahl input/phase splitter transformers. Shoog Tubes / Valves 51 14th November 2008 11:45 AM
Page generated in 0.08859 seconds (71.74% PHP - 28.26% MySQL) with 11 queries
