| diyAudio Sponsor | ||
#31 |
I just ordered tubes for a Fender Champ. I also snagged a 4000 ohm -> 8 ohm output transformer. Seeing as how a 7000 ohm winding is used on the original, this should give me 1.75x what the voltage ouput would be normally?
The output tube is a 6V6. Here's a simple configuration for a parafeed 6v6: http://www.audioasylum.com/forums/ma...sages/318.html |
#32 |
You could build something like the moonlight, but single ended with a resistor load rather than the output transformer. Then simply cascade the output into the gainclone (after attenuating it a bit first of course). If you were feeling very adventurous you could add a choke is series with the load resistor for some added pseudo-speaker mojo I suppose.
#33 | |
I found a 6.7k to 300 ohms interstage transformer on eBay for 10$. Is this suitable for replacing the output transformer in a Fender Champ amplifier? They're usually 7k. http://cgi.ebay.com/AUDIO-INTERSTAGE...QQcmdZViewItem |
#34 |
You can use just about any transformer, if you are prepared to experiement with the interface between the transformer and the gainclone.
Shoog |
| Project Hybrid tube-chipamp | vthieu | Chip Amps | 0 | 3rd February 2008 07:40 AM |
| NUCLON -- My first hybrid guitar amp | Wavebourn | Tubes / Valves | 5 | 26th October 2006 08:04 PM |
| Tube-buffered Gainclone for a guitar amp? | Spasticteapot | Chip Amps | 6 | 4th May 2006 06:42 PM |
| bass guitar amp hybrid Tube/mosfet ?? | partyjups | Instruments and Amps | 1 | 19th April 2004 01:08 PM |
| Any designs for tube/chip hybrid guitar amp? | leadbelly | Instruments and Amps | 5 | 24th November 2003 11:56 AM |
| Page generated in 0.08729 seconds (67.65% PHP - 32.35% MySQL) with 11 queries |
