| diyAudio Sponsor | ||
#11 |
I just got hold of 2 100TH's too.
Had a look at Astouffers diagrams. The 6EM8 should be a 6EM7... Can anybody tell me what kind of output transormer this is?? Thanks! |
#12 |
Hi Eimac
check out this link: www.triodefestival.net/uploads/.../michimori%20(PPTminimizer).ppt this is a cool way to drive the A2 tubes, if you don't like to use a FET. best regards Karsten |
#13 |
Hi Karsten,
A friend of mine built an 811A SE amp adopting the regulator tube drive method to achive 22W output succesfully. He used a SOFTON R-core output transformer. I think SOFTON RW-40-5(40W) can be use for a 100TH SE amp. Best regards H. Michi http://http://www.icl.co.jp/audio/RW40-5/RW40-5.htm http://http://www6.plala.or.jp/Michi...0SE%20Amp.html |
#14 |
Hi Michi-san,
thank you for the information, I can only see this info about the OPT: ソフトン RW-40-5 出力トランス as you can see it is in japanish writing, do you have a english version? BTW are you comming to the ETF this year? please bring a the 8025a amp to the ETF. best regards Karsten |
#15 |
Karsten-san,
I found some of their english Catalog. I am now asking them English catalog of RW-40-5. I am afraid, I can not come ETF2011 this year. I hope I will join ETF2012 in Denmark? As I have many old friends in Copenhagen. Best regards H. Michi Softone/ICL's AUDIO PRODUCTS Renewed 100TH SE Amp 2010 |
#16 |
Hello Hirokuni San!
Feeling good to meet up with you here! Thank you very much for helping me built my SE 811A dynamic coupled amp 16mths ago. Likes your 100th amp ![]() Wish You Good Health Kwan |
#17 |
Kwan-San, long time no see! Hope you are doing OK.
BTW a friend of mine built a 811A SE amp with the regulator tube drive, and the OPT was Softon RW-40-9.5. He used 5K ohm tap and 16 ohm KNF for his 811A amp. Thank you |
#18 |
[QUOTE=211hojbjerg;2673821]Hi Michi-san,
thank you for the information, I can only see this info about the OPT: ソフトン RW-40-5 出力トランス as you can see it is in japanish writing, do you have a english version? I have just received an English Catalog of RW-40-9.5, which is almost same as RW-40-5. Best regards H. Michi |
| What about the Eimac 3-500z? | Toobstheway | Tubes / Valves | 18 | 8th January 2009 06:48 AM |
| Any Eimac Scematics? | ak_47_boy | Tubes / Valves | 7 | 1st April 2007 10:19 PM |
| Fixing this 100TH | Gluca | Tubes / Valves | 1 | 21st February 2007 01:05 AM |
| EIMAC toobz : What sort of PSU ? | coresta | Tubes / Valves | 7 | 14th December 2006 06:23 AM |
| Eimac 35TG | ReinoutdV | Tubes / Valves | 6 | 7th September 2005 03:24 PM |
| Page generated in 0.12336 seconds (73.48% PHP - 26.52% MySQL) with 11 queries |
