| diyAudio Sponsor | ||
I am building a compressor Fairchild 670. I have a doubt, what hope someone of you can clarify.On schematic the r115 double potentiometer ( first channel ) and r215 (second channel)-value 100 K LIN-, seems supplied with a kind of physiological terminal for section. A link is placed between the two terminals. What is it? What type of potentiometer does using suit? What happens if is used a simple double potentiometer ?
Regards, plinio (from ROMA -Italy) |
#2 |
I am very interested in building a Fairchild.
as he was? seen the new valve jj? http://www.jj-electronic.com/pdf/6386LGP.pdf |
| Simple compressor | PeteMcK | Elektor | 4 | 25th August 2009 02:30 AM |
| Mic compressor limiter | fjpompeo | Analog Line Level | 0 | 1st June 2007 11:26 PM |
| Compressor for preamp | impsick | Chip Amps | 4 | 24th March 2007 05:58 PM |
| This compressor needs more controlls | Domplotz | Instruments and Amps | 2 | 19th September 2006 11:04 PM |
| Compressor diy | XXLPeanut | Instruments and Amps | 5 | 14th June 2006 11:55 PM |
| Page generated in 0.06882 seconds (62.28% PHP - 37.72% MySQL) with 10 queries |
