High dollar power cords ...Myth or magic - diyAudio
Old 17th December 2002, 02:21 AM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Are $200- $300 power cords worth it - I don't think so
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th December 2002, 03:03 PM   #2
Joel is offline Joel  United States
Joel's Avatar
I bet the retailers who sell them think they are magic.
Old 17th December 2002, 03:53 PM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Joel,
Seems as though you've already made up your mind.
To others,
I have some ideas why some people (and not others) might find a difference:
I am one who doesn't.
But I...
Don't use equipment with Switchmode PS's
Nor equipment that affects the mains' "form factor" measurably
Do use balanced interconnects
Could there be a clue in there?
Old 17th December 2002, 04:31 PM   #4
fezz is offline fezz  United Kingdom
i really dont think power chords make a difference, unless we are talking about shilding, where better shilded power cables would reduce the ammount of interferance into over cables such as interconnects or speaker cable.
appart from that they do not change the sound - as the powersupply cleans up the power anyway
Old 17th December 2002, 04:46 PM   #5
Power cords certainly don't make a difference in my system.
www.audiosector.com
Old 17th December 2002, 06:41 PM   #6
However, in my wife's system the cords make tremendous difference. Changing cords and changing outlets shows immediately in sonic signature.
She was always the messy one. Gainclone in a center. I am really surprised with the abilities of this little chip. Sounds very promising, yet very dependant on a proper setup. Using acrylic feet or no feet, can be heard right away.
www.audiosector.com
Old 18th December 2002, 02:45 PM   #7
mrfeedback's Avatar
Default Portable Power Plug Permutations...
Pete, I have found different removable AC cords can make a difference and that switching the polarity makes another difference too.
Regarding hifi gear power leads, I find silicone insulated (industrial and stage lighting) flex power cable makes a very agreeable difference to audio gear.
As for feet, I find differences according to the material used, in addition to the shape of them and positioning.
Lately I am finding spring steel engine valve springs work great, and particularly under heavy items including speakers.
Eric.
I believe not to believe in any fixed belief system.
Old 18th December 2002, 03:33 PM   #8
Default High Dollar power cords
The discussion has moved a little from the topic heading.
High Dollar Power cords, Myth or Magic.
O.k., wire makes a difference.
Do you have to spend a lot?
Cheers
Craig Ryder
Ryder
Any fool can ask more questions than seven sages can answer.
Old 18th December 2002, 03:37 PM   #9
Default Re: High Dollar power cords
Not at all. By smart shopping and good selection you can pull it off really cheap. At least that's what I'm doing.
www.audiosector.com
Old 18th December 2002, 03:41 PM   #10
diyAudio Senior Member
fdegrove's Avatar
Default EL CHEAPO
You can even roll your own:
SOLID CORE MAINS CABLES
See page 2.
Frank
Power Cords patherb Everything Else 6 9th March 2009 05:01 PM
Shunyata Power Cords.... Voltaic The Lounge 10 3rd July 2006 01:44 AM
power supply cords jaudio Chip Amps 2 29th January 2005 08:43 PM
power cords lopan Parts 9 16th September 2004 02:42 AM
Are $200- $300 power cords worth it - I don't think so alvaius Everything Else 110 18th December 2003 04:12 PM
Copyright ©1999-2017 diyAudio
