diyAudio Sponsor
Old 29th September 2006, 04:09 AM   #1
TomWaits's Avatar
Default ODD TUBES, what to look for?
I 'm reading the thread "Favourite Tubes" and after reading all of your posts I want to know what rare but odd tubes often get over looked?
I have access to a few tube surplus sellers and often they only pick out the classic valve part numbers and leave behind tonnes of candy to harvest?
We all know 6L6 , 6550, 300B, KT88, EL84, on and on...
BUT what tubes often go unnoticed that have great value including rectifier types. I want to know so I can become a better shopper and you guys seem to know the odd gems.
I want to compile a shopping list of cheapies and oddities to hunt for and I would love to see your suggestions.
Thanks,
Shawn.
Old 29th September 2006, 07:18 AM   #2
Interesting question! I recommend that you give a look at Geek's forum. There are lots of curves traced for odd tubes, triode strapped pentodes etc. Some really good things among them!!
http://geek.scorpiorising.ca/GeeK_ZonE/index.php
Both Geek and Serpentine are members of diyaudio, Serpentine under the nickname 4E4
Old 29th September 2006, 07:46 AM   #3
Ouroboros's Avatar
I'm a fan of the 829B, using two of them (with both sections paralleled) for a push-pull amp. An OPT with a primary Z of about 4.5k seems to work well.
Beware that there's a lot of late-manufacture RCA ones about (with the big red RCA logo) that appear to be quality rejects.
Old 29th September 2006, 08:14 AM   #4
Tweeker is offline Tweeker  United States
Sweep tubes.
Be sure your foil hat has a good low impedance ground.
Old 29th September 2006, 08:20 AM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Odd you should mention that. I bought a batch of fifteen and when I tested them on my valve tester, four were duds for one reason or another.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 29th September 2006, 11:17 AM   #6
One simple answer is loctals. Get some loctal bases and save mucho money. A lot of the standard tubes were made in loctal equivalents. Note that most of those below came in 14*** versions which were 12v tubes, and are even cheaper. None of these seem to move on ebay - they're a goldmine which is constantly overlooked and prices are static. Be sure to widen the locking base with a pair of long nose pliers - just pull the two ears apart. these tubes are meant to lock and some do a good job of coming apart in your hand when you try and prise them out (had two CV391s fall to pieces - thin glass).
Approximately speaking:
7N7 = 6SN7
7AF7=6SN7 round plate
7A4=6J5
7C5= 6V6
KT81=KT61
CV391=807
3A/167=437a
7F7=5751/6SL7
7B4= half a 5751/6SL7
7Z7=EZ80/81
There's even some DHTs
1LE3 mu 14.5
3B7 double triode
Old 29th September 2006, 12:01 PM   #7
Tubes4e4's Avatar
Hi Erik,
Actually it is "Tubes4e4"
Here´s the link to the index page of traced curves: Some tracings
Tom
If in doubt, just measure.
Old 29th September 2006, 02:40 PM   #8
tubelab.com's Avatar
In my case I already have a few zillion oddball tubes. I look for tubes that have physical characteristics (the guts, not the envelope) similar to what I need. If I am looking for an output tube, I look for a tube with a large plate structure. If I need a driver tube, I look for a medium sized triode, or dual triode (or triode wired pentode). If I need an input, or preamp tube, I look for a small triode or dual triode. If I find a tube, that I have a few of, that meets the physical criteria, I look it up. Observation of the electrical characteristics can eliminate a few possible choices. It is likely that I have one or more of the target tubes that are physically damaged. I will often take them apart to look at the internal structure. After doing this for a while you learn what works, and what doesn't. Control grids wound with uneven spacing causes distortion.
If the tube has a chance of success, I hook one up and test it in the indended application. I use a breadboard system with all power supplies adjustable, to find the sweet spot for the particular tube. If one tube shows promise, then I test a bunch of the same tube to see how repeatable they are. If I like the particular tube, I will torture test a few of the ugly ones to find out how reliable they are. It is not uncommon to find (especially power tubes) some samples that self destruct at the spec limit, while a different brand of the same tube will live happily at twice the published ratings.
After you have done this, you will have identified a few tubes that were previously unknown. It is also possible to find a tube that has been previously shunned by the audiophile community that works well under different conditions than the audiophiles use.
In this audio world it would appear that a few people state the "facts" and they are blindly accepted by the majority. This happens a lot on one of the other audio forums. For instance, it is an accepted fact that the 12AU7 is not a good audio tube. This I haven't tested yet, but since I have about 1000 of them, I will. I have also heard the same about the 12AT7. I was searching for a good driver tube, when I discovered a large box full of 12AT7's. I wired one into a simple breadboarded SE amplifier using the common resistor loaded circuit, biased at the usual 2 - 3 mA. I tested the distortion spectra, and listened to the resulting (mono) amp. It would seem that the world was right, a thin sounding amplifier with a large amount of third and fifth harmonics. If I had given up there I could have said that the audio world was right. After a lot of experimentation, I discovered that this tube likes more current (5 to 10 mA) and a CCS load. Under these conditions a 12AT7 works really well.
There are some tubes that just won't work for HiFi use, no matter how long you play with them. There are others that have a wide variation from tube to tube. The wide variation can be OK for a one off amplifier, but will kill you if you plan to build a few amps.
I have learned to avoid tubes designed for "gain controlled RF amplifier" or "AGC controlled IF amplifier" use. These are often called remote cutoff pentodes or variable Mu triodes. These usually have too much distortion for the signal levels found in most audio gear. They may be useful in phono stages.
Every few months Antique Electronics Supply sends out a flyer that lists a page of "bargain tubes". As soon as I get it I look up all of the under $2 tubes to see if any are useful. I found 3 in the latest flyer, and ordered 80 tubes. As if I don't have enough tubes already.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 29th September 2006, 03:22 PM   #9
EC8010's Avatar
Ah, but in percentage terms you've scarcely increased your valve stock at all, so that's alright.
Old 29th September 2006, 08:30 PM   #10
kstagger's Avatar
EF40 = rimlock socket version of the EF86
ECC40 = rimlock socket dual triode
EL38 - nice power pentode with a plate cap
1633 - 25V filament version of the 6SN7 - used for aircraft radios?
1631 - 12.6V filament version of the 6L6
6C6 - plate cap pentode - RCA's version of the 310?
5X4G = same as 5U4G, different pinout
5Z4/GZ30 - good for low current power supplies
and the usual 12SN7, 12J5, 12SL7, 12SJ7, 12SX7 tubes
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 10:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 01:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 07:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 12:26 PM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 10:22 AM
Page generated in 0.15106 seconds (83.35% PHP - 16.65% MySQL) with 11 queries
