diyAudio Sponsor
Old 29th September 2006, 07:37 PM   #11
aerius is offline aerius  Canada
Loctals were already mentioned, but another cheap trick is to look for the same tube in a different voltage, a 12SN7 or 12SL7 instead of the 6 volt ones for instance. There's also the 6A3, and the 6AU7 instead of 12AU7.
Old 29th September 2006, 09:34 PM   #12
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Compactrons.
Tubes and sockets are available on ePay.
Old 29th September 2006, 10:45 PM   #13
Miles Prower's Avatar
Originally posted by tubelab.com
In this audio world it would appear that a few people state the "facts" and they are blindly accepted by the majority. This happens a lot on one of the other audio forums. For instance, it is an accepted fact that the 12AU7 is not a good audio tube. This I haven't tested yet, but since I have about 1000 of them, I will. I have also heard the same about the 12AT7. I was searching for a good driver tube, when I discovered a large box full of 12AT7's. I wired one into a simple breadboarded SE amplifier using the common resistor loaded circuit, biased at the usual 2 - 3 mA. I tested the distortion spectra, and listened to the resulting (mono) amp. It would seem that the world was right, a thin sounding amplifier with a large amount of third and fifth harmonics. If I had given up there I could have said that the audio world was right. After a lot of experimentation, I discovered that this tube likes more current (5 to 10 mA) and a CCS load. Under these conditions a 12AT7 works really well.
I've found it helpful to take a good LQQK at the specs. The suggested plate currents for the 12AT7 are a good deal higher than what a lot of folks seem to be running with. That's where I'd certainly start looking for a good loadline. Of course, the main problem here will be less Av since the Rp's will have to be smaller with reasonable Vpp's. Still, you can always use an active load if you need high gains, or make up for it with a preceeding stage.
As for 12AU7s, these appear to work best as SRPP's and Mu Stages, or possibly as LTPs with a tail CCS.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 30th September 2006, 06:29 PM   #14
TomWaits's Avatar
Thumbs up Expanded shopping list
Great feedback. I have a much bigger shopping list now.
Thanks,
Shawn.
Old 30th September 2006, 08:41 PM   #15
wa2ise is offline wa2ise  United States
wa2ise's Avatar
There exist tubes like 8BQ5, 11BQ5, 8CG7 and so on. The same as their 6 volt cousins except for the oddball heater voltage. BTW, if you have a 12.6VAC supply avaliable, you can connect an 8V heater to it in series with a SS rectifier diode, no filter cap. This yields about the same amount of heater power that 8V AC would give directly. If all you have is 6.3VAC, run that thru a bridge rectifier and use a filter cap to get 8VDC to run the heater.
Old 30th September 2006, 08:47 PM   #16
Wavebourn's Avatar
Originally posted by wa2ise
There exist tubes like 8BQ5, 11BQ5, 8CG7 and so on. The same as their 6 volt cousins except for the oddball heater voltage. BTW, if you have a 12.6VAC supply avaliable, you can connect an 8V heater to it in series with a SS rectifier diode.
If to rectify 6.3V by Shottky diodes you'll get 8V DC. I use such trick to power compactron filaments. 8JZ8 is the example (one triode + power pentode in triode connection to drive power FET follower)
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 30th September 2006, 08:50 PM   #17
Mega-bad idea there. That will also yield lots of harmonics that'll add uncorrelated noise to the signal, and really do the sonics no good at all. If you're going to use DC for heating, it needs to be well filtered to get rid of those objectionable harmonics. Otherwise, DC heater power sounds worse than using AC. Better to drop the excess AC with a series resistor.
www.dolphin-hsl.com
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 06:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
Page generated in 0.12392 seconds (77.27% PHP - 22.73% MySQL) with 11 queries
