Completely new to building amplifiers - Page 3 - diyAudio
Old 19th December 2002, 08:43 AM   #21
Brett's Avatar
Take a look at this thread too. It discusses the Quicksilver KT88 UL PP amp, which would also be a good one to clone. The schematic posted is for the version using the very rare 8417 tube, but hopefully someone will work out the differences and post them.
Quicksilver KT88 mono 60watt amp schematic
Old 19th December 2002, 10:39 AM   #22
diyAudio Senior Member
fdegrove's Avatar
Default FROM 8417 TO KT88/6550
Actually the differences aren't huge and easy to do:
http://www.triodeel.com/8417.htm
You can also implement the modification to the PSU as Joe posted in the Quicksilver thread.
Easy peasy.
Frank
Old 19th December 2002, 10:53 AM   #23
Frank and others..
I will make the changes and post the amplifier section of the KT88
mono block Quicksilver amplifier next week as I am off that week and will have the time to do it. This may serve as an interesting topic as well as a good building tool to follow?
As I have nothing to compare the modified power supply to I must admit that I find it very smooth and also an am not hurting for bass response.
If I had known the information existed for modifying a 8417 amp I probably would have purchased a used pair off ebay for less than I paid for these KT88 mono's. Either way I am very satisfied with the performance of these amps.
Joe
Old 19th December 2002, 11:04 AM   #24
fdegrove's Avatar
Default KT88 SCHEMATIC
That would be nice,thanks Joe.
Frank
Old 19th December 2002, 11:18 AM   #25
Brett's Avatar
Looking at it again, I'd build the GEC over the Quicksilver, with a couple of minor mods. I'd phase split before the 12AX7s with a Lundahl LL1544A, or similar Jensen trans, make it balanced in, and put a CCS in the tail of the first two stages down to an extra negative supply (-20V?). The last is just my preference for a real diff stage, rather than PP.
Old 19th December 2002, 11:22 AM   #26
Brett's Avatar
Default Addendum
If someone were to build the QS, a pair of Dyna 431 like those out of the Dyna Mk3 would be good candidates for OPTs.
Old 19th December 2002, 12:29 PM   #27
Default Tube manuals
No, I do not have a tube manual. Where might I acquire such a thing? Do these include schematics?
There are a few online:
1) Sylvania Tube Manuals (1943,49 and 1959)
http://www.montagar.com/~patj/electro.htm
2) RCA Radiotron Tube Manual, No. R-10 (Tim Reese’s site) http://www.nmr.mgh.harvard.edu/~reese/RC10/
3) RCA HB-3 Tube Manual (Pete Millett’s site) http://www.pmillett.addr.com/hb-3_tube_manual.htm
4) Karl R. Spangenberg, On Vacuum Tubes. (Ken Gilbert’ site) Used by grad students at Stanford studying vacuum tube design in the 40s. http://ken-gilbert.com/spang/spangenberg.html
These are in the outline of online tube info I sent you.
The first 25 pages of tghe R-10 is worth the read while you're waiting for F.
At least you can see what one is.
cheers
Craig Ryder
Ryder
Any fool can ask more questions than seven sages can answer.
Old 23rd December 2002, 04:00 PM   #28
Default DIY
What do you all think of the feasibility of a stereo SET putting out about 60W per channel? Or do you think that monoblocs would be better?
I am debating what to do here with making a project. I am eager to get going...
Old 23rd December 2002, 04:06 PM   #29
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
60W is feasable with PSE. Otherwise we're talking "exotics".
Whether monoblock or not makes no difference in performance for a properly designed system. The main reason for 2 chassis' is weight.............But as you're T_Strong...maybe you can manage
Old 23rd December 2002, 04:48 PM   #30
Default DIY
dhaen: PSE? For clarification, is that Pentode Single Ended? or am I off?
FS: Building Valve Amplifiers by Morgan Jones RockysDad Swap Meet 4 8th November 2008 05:25 PM
And now for something completely different ...... MJK Full Range 38 20th February 2006 04:59 PM
Something completely different Ulas Digital Source 0 16th August 2005 02:28 AM
And now for something completely different.... ThorstenL Everything Else 47 24th December 2002 02:04 AM
Copyright ©1999-2017 diyAudio
