diyAudio Sponsor
Old 28th September 2006, 11:00 PM   #1
Default 2A3 SE and Edcorp tranny
I've got a couple of new Edcorp SE transformers 5K ohm.
http://www.edcorusa.com/classx/tube_...xse15-8-5K.htm
I want to build a simple 2A3 SE amp so my question is can I use these transformers??
I would appreciate any help with locating a schematic etc also.
Steve
steve
Old 28th September 2006, 11:59 PM   #2
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Do you want to achieve the most output power? With 5K on a 2A3, you will get less distortion at less power.
If I have that transformer, I'd make -
a) 45 amp
b) 300B
c) 807 with UL tap
Old 29th September 2006, 12:22 AM   #3
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
http://images.google.com/images?q=2a...0&sa=N&ndsp=20
Old 29th September 2006, 12:29 AM   #4
Fuling is offline Fuling  Sweden
Perhaps a different OP with higher voltage and lower current would suit the higher impedance better?
Something like 300V 50mA instead of the typical 250V 60mA for 2A3.
Old 29th September 2006, 02:13 PM   #5
kmtang is offline kmtang  Canada
kmtang's Avatar
Hi Steve,
It would be a waste of the 2A3 with Edcopr OPT. 2A3 is a very good sounding tube that it is worth to match with good quality OPT.
If you want to keep the cost down, get the Hammond 1627SE, or James 2.5K OPT.
My friends and I have good experiences with Hammond and James.
Johnny
Old 29th September 2006, 03:44 PM   #6
tubelab.com's Avatar
I agree that the 2A3 can be a good sounding tube, and is often used in expensive amplifiers with expensive transformers. That does not mean that it should not be used in a budget amplifier. You can get Shuguang 2A3's for under $30 each.
The Edcor XSE15-8-5K is a nice sounding transformer and at the 2 watt level it will compare with many of the big boys especially if your speakers are limited to operation above 60 or 70 Hz. For $20 each it is the OPT deal of the moment. Add the $40 Allied 6K56VG power transformer and you can have a relatively good amp for a good price.
I have used these transformers with 2A3's although I am not a 2A3 fan. I prefer the Shuguang 300B. A 5K transformer will work on either tube with slightly reduced power output, but reduced distortion. As mentioned before, run the tube up near its maximum voltage rating at a lower than normal current to take advantage of the 5K load.
I am partial to my amplifier design, but it may be too complex for an inexperienced builder:
http://www.tubelab.com/TubelabSE.htm
It is possible to use the Simple SE circuit with a DHT, but you may need a DC filament supply for the 2A3. I do not yet have the entire schematic on my site, but it will be there in the next few weeks. The PC board schematic can be found here:
http://www.tubelab.com/SimpleSE_schematic.htm
There are dozens of 2A3 schematics on the web. Google around, and find something that you feel is within your abilities.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 30th September 2006, 02:04 AM   #7
What voltage can a 2a3 safely operate at? the datasheet claims 300v, but that seems a little low for the deisgns i've seen it in
Old 30th September 2006, 02:36 AM   #8
Geek's Avatar
Short answer from experience, most likely yes.
I have heard this transformer up to 5.5 watts with a trioded EL36 (which has a very 2A3 sound) and you can easily get 24 - 19.5KHz with zero NFB at that level. Toss in 3dB NFB for full 20 - 21KHz.
Same great sound from a "little 2A3" (the 45) with extended response.
I've used bias up to 60mA with this transformer with no loss in performance.
I say most likely, because I have yet to hear a genuine 2A3 with it.
Old 30th September 2006, 03:33 AM   #9
I have used this transformer with at least a dozen different tubes, including twin plate RCA 2A3's and Shuguang 2A3's. I have never been a 2A3 fan, but they sound very good with these transformers. The frequencies above 200 Hz have as much if not more life to them as transformers costing much more. In the 20 to 80 Hz region this transformer will saturate at powers above 5 watts. This is not a problem at 2A3 power levels.
I run 45's and 2A3's at 325 volts this is way over the line for a 45 and a little over the line for 2A3's. I have not had any issues yet, but YMMV.
Old 1st October 2006, 12:16 PM   #10
Thanks to all for the comments and reccomendations.
Tubelab, I'm leaning towards your simple se board since this is really sort of and experiment for me. I'll email you re this.
I would appreciate comments from all on this schematic also . (of course I would like to use my Edcorps txs since they seem like a pretty good fit. (I know theyre not ideal) I'm really trying to get a feel for the sound of a low power SE amp without spending a ton of money.
http://www.angela.com/catalog/how-to/SE.2A3.html
Steve
steve
Now I know what this Tranny can do Tarzan Tubes / Valves 3 8th January 2009 08:37 AM
Tranny Qs? henkel Parts 4 12th September 2006 04:58 PM
What can I do with this tranny? ThSpeakerDude88 Chip Amps 15 28th July 2005 04:29 AM
what should I do with this tranny??? mylesmf Tubes / Valves 6 9th June 2005 12:42 AM
How to use LED with +- 25v tranny? ransom peek Chip Amps 21 29th March 2005 12:55 AM
Page generated in 0.11970 seconds (80.82% PHP - 19.18% MySQL) with 10 queries
