diyAudio Sponsor
Old 28th September 2006, 11:02 PM   #11
valveitude's Avatar
leadbelly-
Which model, the WSM10K/10K, or the XSM10K/10K?
The XSM10K/10K
jrdmedford-
They cant take any DC current imbalance in the primary except for maybe a milliamp or so.
The Edcor site states that the AC+DC Current capacity is 50ma. I assume you meant the current needs to balanced referenced to the center tap. I don't see why you couldn't drive them with a SE drive stage, as long as your idle didn't exceed 25ma or so...then again maybe I'm missing something
-Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Old 30th September 2006, 03:35 AM   #12
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
How much would you pay for such a tranny: $11, or $120?
(The 1'st picture is for 20 Hz, the second is for 200 Hz, the third is for 20 KHz)
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 30th September 2006, 05:04 AM   #13
I'd pay $11 for that. Here's why: The 20Hz performance is
impressive as its clearly passing the fundamental and the 2nd, 4th
etc very nicely. However, the 20kHz performance sucks - not
because of the phase shift, but the attenuation of the fundamental
is what, -1dB or so? I'd expect it flat out past 20kHz, perhaps
down to 60kHz because you start seeing attenuation.
Also, you are passing 0.5V. Lets see it with 10Vp-p...
I'm not saying that it wont sound good.... I'm sure it sounds wonderful since a slight knockdown at the top end of hearing tends to "round out" sound and make it more relaxed to the ear. Whats more, its not going to be shy in the bass.
Also, the nickel transformers are $120/pr, or $60 ea. Minus shipping.
The Edcor is $11. For $50 more, you are not paying DEARLY for improved performance. Consider if you are building "pro" gear, you
have to use wide-bandwidth stuff - because equipment gets chained together in the studio... How many -1dB cuts at 15kHz can you accept?
The other thing you get with Nickel is the permeability, which seems
to do something to the sound - i.e. attack, low-level dynamics etc.
-- Jim
Old 30th September 2006, 05:28 AM   #14
Wavebourn's Avatar
-- Jim
Jim;
It is "Pro" from Altec-Lansing; far the more, if source would be as specified 600 Ohm instead of 50 Ohm I used...
I'll sell it on ePay for $30 and buy what you recommend for $11.
Speaking of modern studios, we build perfect amplifiers to listen to programs recorded on interconnected gear wilh 30 Ohm outputs and 100K inputs...
Old 30th September 2006, 03:23 PM   #15
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Would also like to if you can have a standing current of 50mA DC.
Regards Åke
Using mains transformer as output transformer Elias Tubes / Valves 175 3rd November 2009 08:36 PM
Modulation transformer for a driver transformer? ironradio Tubes / Valves 6 28th December 2008 05:05 PM
filament transformer vs plate transformer contaxchen Tubes / Valves 10 14th January 2005 10:43 AM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
Page generated in 0.10107 seconds (75.86% PHP - 24.14% MySQL) with 10 queries
