diyAudio Sponsor
Old 28th September 2006, 01:09 AM   #1
Default Passive Pre-Amp causes huge power loss?
I built a passive preamp for my old tube amp using only the proper connectors and a pot. The problem is that I lose over half of the volume even when fully torqued?
I did connect all of the grounds together at the pot ground...Is this wrong? The grounding was my only confusion...but it plays?
Thanks,
Dominick
A real amateur enthusiast!
Old 28th September 2006, 01:27 AM   #2
Enzo is offline Enzo  United States
What value is the pot? Is it wired right to a grid?
I doubt the grounding is an issue, you are loading the signal down.
Old 28th September 2006, 01:29 AM   #3
Grid?
It isnt wired to anything. I tried both a 100k pot and a 10k pot.
Same results.
Also, as I turn the pot, the volume goes up and then back down as I continue turning.
Dominick
Old 28th September 2006, 01:58 AM   #4
Please include your schematic.
Old 28th September 2006, 02:30 AM   #5
Here is a rough sketch!
Dominick
Old 28th September 2006, 02:38 AM   #6
aerius is offline aerius  Canada
Dominick
That's odd...is it possible you got a balance pot by accident instead of an audio taper pot? If the volume starts going back down once you hit the halfway point on the pot's rotation, chances are you got a balance pot.
Old 28th September 2006, 02:40 AM   #7
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Your connection is not correct, the center pin should be out, not ground.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th September 2006, 02:52 AM   #8
Tuukka is offline Tuukka  Finland
Tuukka's Avatar
try this
Old 28th September 2006, 03:02 AM   #9
Peter and Tuukka,
LOL,
Sometimes I overlook the smallest things and stump myself. Problem fixed. Thanks so much...Now I can tone it down for the neighbors!
Dominick
Old 28th September 2006, 11:34 AM   #10
As stated above.. when looking at the back of any pot the ground is on the left, out the center, and input on the right.
That is when you face the tabs up.
HELP! my amps loss power rrlax24 Subwoofers 1 8th November 2006 09:02 AM
Extremely low power and low loss transformers percy Tubes / Valves 12 23rd February 2005 11:30 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 10:16 PM
SPL loss with passive XOs Rocky Multi-Way 2 15th June 2004 02:53 PM
Good price on huge power transformer for power amp. G Solid State 3 15th September 2002 02:23 PM
Page generated in 0.10655 seconds (72.81% PHP - 27.19% MySQL) with 11 queries
