| diyAudio Sponsor | ||
#11 | |
Actually when I had all the failures with the Phillips bulbs I pulled out the meter and went around checking. No DC on the line. The only thing I found was that my mains voltage could be as high as 124 VAC and as low as 119 VAC. I went next door and tested their outside outlets at the same time and found the same voltages, so nothing especially odd about my house. I check my mains voltage pretty often since I like to double check my B+ voltages against what is happening in the house AC. I have also put my scope on the raw AC and haven't seen anything untoward. I haven't had any problems with any other electronic equipment. I have a small computer network here, a couple servers half a dozen workstations, four or five printers, switches, routers etc. with nary a peep. Also my amps seem to perform just fine, though with B+ voltages a little higher than spec'd due to the higher mains voltage. I think CFL bulbs just don't like me.
--Sherman |
#12 |
Did it Himself
By upside down do you mean the bulb end is pointing towards the ground? I've moved house 4 times since 1999 and taken the Philips Ecotone bulbs with me every time, not had one go yet. They are all pointing towards the floor in normal light fittings, except for one upward pointing one in a lamp.
Recently fitted a fluorescent tube light in my loft, can't remember if I got it from Focus or B&Q. No problems with it though.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#13 |
I heard that poltergeist is quite common in England...
| transformer rubbish | lt cdr data | Tubes / Valves | 26 | 25th April 2009 01:30 AM |
| using flash camera (and maybe laptop screen or fluorescent) inverters to power tubes | ionomolo | Tubes / Valves | 6 | 10th December 2008 01:30 PM |
| small fluorescent lighting at wallmart | karma | Everything Else | 6 | 1st December 2005 01:47 AM |
| Page generated in 0.08717 seconds (74.47% PHP - 25.53% MySQL) with 10 queries |
