| diyAudio Sponsor | ||
I just got a tube integrated amplifier with both 4 ohms and 8 ohms speaker connection.
I have an Acoustic Research floorstander with a rating of 6 ohms. Where should I connect the speakers to the 4 or 8 ohm connection? Thanks. |
#2 |
You can try both. Theoretically the 4 ohm tap would give less power and less distortion. The 8 ohm tap would give more power, and more distortion. This has to do with a different load on the tubes. In practice it probably doesn't make much difference, as the speaker is far from being 6 ohms on it's whole range.
#3 | |
Thanks. |
| speaker that can be driven by tube amp | milen007 | Tubes / Valves | 26 | 6th May 2008 06:36 AM |
| What speaker to use with my tube clone | elementx | Tubes / Valves | 11 | 1st December 2005 07:34 PM |
| Tube amp for biamped speaker | navin | Tubes / Valves | 39 | 25th November 2005 11:36 AM |
| Speaker tube amp with headphones | Simpleton | Tubes / Valves | 6 | 7th April 2005 03:01 PM |
| tube amp/speaker match | vangre | Tubes / Valves | 10 | 8th December 2003 06:06 PM |
| Page generated in 0.06189 seconds (78.78% PHP - 21.22% MySQL) with 10 queries |
