#151 |
Did you guys still interested or are you thinking about it?
Later Bruce
What ever makes the tunes flow |
#152 |
i'm still thinking about the circuit, and how we're gonna wire it up. need to think out the details.
anybody have parts suggestions for the tweak circuit? i'm thinking Hovland feedback cap, Black Gate coupling cap, maybe Caddock MK132 resistors... for the cheapo version, i think we should use "crappy" metal films. those Radio Shack carbon films actually don't sound so bad. |
#154 |
silver mica is actually pretty nice stuff. but we only need two caps - .22uF film and 10uF 'lytic. i'm not sure what to use for internal wiring, i like Cardas litz but it's harder to work with. any decent solid core with non-PVC insulation will do.
oh yeah, we need a couple larger 'lytics for the power supply bypass. i like Nichicon Muse or Elna Cerafine/Silmic. i hear OSCON is good too but i don't have any. |
#155 |
diyAudio Senior Member
Hi guys,
Just a little suggestion I'd like to make for the crappy unit: throw in a couple of resistors with magnetic leadout wires? Preferably either in series with the signal or as load resistors. Cheers,
Frank |
#156 |
yes, i was thinking steel endcaps and lead wires. i believe Yageo resistors from Digikey are magnetic, i will check.
#157 |
I have to go see the Doc this afternoon so I'll talk to you guys later. I'm thinking the simplest possible active circuit would be the best choice, a CCS follower perhaps. I haven't heard the one you favor Dorkus. It could well be the best choice. I have the parts to build up a follower that I have used for years and as far as I can tell has all most no signature of it's own. Maybe we could each build a one channel active stage (no switching) to sent to the others for evaluation and pick one as the test circuit.
Later Bruce
#158 |
Any new thoughts today guys?
#160 |
i'll heat up the iron after the new year.
| Hafler parts - Sound Valves? | DMF | Solid State | 21 | 24th March 2010 08:12 PM |
| SMD parts on Julia sound card blown. | ashok | Solid State | 16 | 27th February 2007 02:47 PM |
| help!, diy sound card parts problems | gideon | Digital Source | 6 | 7th August 2006 09:06 PM |
| Magnetic parts sound worse because of... | Bernhard | Parts | 20 | 2nd February 2004 09:05 AM |
| Do hi-fi parts really sound better? | Shaun Perez | Parts | 54 | 24th October 2002 03:49 PM |
