SMPS for B+ discussion
Old 14th November 2006, 12:12 PM   #31
ackcheng is offline ackcheng  Hong Kong
Send a message via ICQ to ackcheng
Magnified photo: 0.35W output at 1Khz, 1khz ripple at 400mV. A problem with OTL circlotron design
Old 14th November 2006, 12:15 PM   #32
At full load: 88Woutput, 2Vripple at 100hz¡A5V ripple at 1khz.
Old 14th November 2006, 12:16 PM   #33
Now, the same amp with SPS80HV and 5400uf filtering cap
0.35W output at 1Kh, measured at B+.
Old 14th November 2006, 12:20 PM   #34
Magnified view: 0.35W output at 1Khz, measured at B+ : 400mV ripple at 1KHz.
Old 14th November 2006, 12:23 PM   #35
At full load: 88W output¡A1V ripple at 100Hz, 5V ripple at 1khz
Old 14th November 2006, 12:25 PM   #36
Attached is the summary of the measurement report
Old 14th November 2006, 12:36 PM   #37
In summary, SPS80 only drops 7.7V but the linear power supply drops 23V. It is obvious that the SPS80 is far superior in loaded condition. There is some improvement in terms of 100Hz ripple and 1K Hz ripple. With additional 5400uF, there is further improvement by 0.9V.
In terms of sound, the SPS80 is so much better. The bass slam is clear, solid and transparent. It is actually more quiet than the LPS. The background is dark black. There is no need to go back to LPS anymore!
When someone tell me again that SMPS is noisy, now I have proved to myself that a good SMPS is better than LPS in all areas!!
However, I think SMPS is good for OTL as the current output is very large. In our measurement, the current at full load is 1.3A, but in theory, the peak current can reach 4A. However, SMPS may be overkill in transformer output amp!?
SMPS for B+ discussionHide this!Advertise here!
NOS ADC discussion anthonybisset Digital Source 32 15th September 2007 02:56 PM
Car HU Discussion fr0st Digital Source 4 11th March 2004 07:42 AM
