diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   SMPS for B+ discussion (http://www.diyaudio.com/forums/tubes-valves/87179-smps-b-discussion.html)
ackcheng 26th September 2006 04:23 AM
Hi!
I am thinking about using a SMPS for the B+ in a poweramp (for output tubes). The SMPS from here
http://www.coldamp.com/opencms/openc...html?idioma=en
seems to have an center tap which is isolated from the main ground. Joining the -ve rail to the circuit ground and the +ve rail will give 120V supply. However, will the switching noise gets into the circuit and affect the 1st gain stage?
How about using different wall sockets. One for the first gain stage and a different wall socket for the output stage and isolating the 2 stages electrically. Woudl this solve the problem?
ssanmor 29th September 2006 08:45 AM
If you purchase a supply and ask for it, we can supply a couple of chokes for free that we usually add in series with the supply lines when operating the SPS80 with our Class-D modules to avoid noise to interfere with them and produce "beating" or "whistles".
They help a lot in cleaning up the rails. However, you will almost for sure find them unnecessary in a conventional amplifier.
richwalters 3rd October 2006 02:42 PM
Re: SMPS for B+ discussion
Originally posted by ackcheng
Hi!
This is asking for trouble especially when earth circuits are joined up, a circulating earth current could create problems in supporting equipment. As I see it, if you want to use 2 smps within an amp (one for power stage and other for front end) with a common chassis, that means 2 xy input filters sharing a centre ground. This is against EMI rules because in the case of a physical earthing fault within the chassis one could see double leakage Y capacitor current. Switchmode power supplies running at different frequencies can create a host of problems esp towards common and differential mode earthing. Generally I find the noise levels not low enough.....i.e much better filtering is required for HiFi applications.
richj
More smps = more interference.
On safety grounds
ssanmor 3rd October 2006 02:49 PM
Well, obviously, the more SMPS, the more EMi, but in the case of SPS80 it is so low that we have been running multiple SMPS in the same chassis with no problems at all. The audible noise level was such that you couldn't hear more noise than a _very small_ hiss inherent to the amplifiers. And that was glueing your ear to the tweeters! ;)
The amplifier was actually a 19" 1U rack, formed by 3 SPS80 + 6 BP4078 class D modules, all running free. It is actually working at a recording studio, I think, and no noise problemas have appeared, and there's lot of electronic stuff in that environment.
You must be careful with the cabling but... nothing more.
I think that with valve amplifiers it will be even less prone to problems, as they don't switch as Class-D amps do.
By the way, SPS80 PSUs have onboard mains filter.
Hope this helps
richwalters 3rd October 2006 03:49 PM
Ooop's understatement ! Some tube amp designs do have s/n ratios down in the -80 to-90db/w ballpark where one would see fine grass electron noise. That's a magnitude lower than current EMI levels for smps between 1-10MHz... however I've lost track and bit out of date of current FCC/ECC legislation levels.
Traditionally, earthing the circuit wiring of tube amps was made only at one place i.e input socket directly connected to chassis, and no other place. Put an SMPS onboard and the earthing circuit for the tube amp is fine but for the smps the tube amp earth is often too high impedance. I had this problem and the only way is to thicken up all earth wiring and even braid the power end return to the chassis. It isn't hit and miss and with stereo circuits things can get quite difficult, it's a question of providing the lowest impedance return for charge injected smps noise and not upsetting amp channel crosstalk rejection at 15KHz. Experience is often the only way and bad cabling will show this up.
This is probably the reason why smps get bad press on tube amps.....lack of EMI understanding on how to redress problems and conflicts....An RF engineer should swallow this with ease... .
Go carefully with the live sides....
richj
ackcheng 3rd October 2006 04:10 PM
ssanmor
You mean you get hiss from the SPS80? I thought the switching frequency is way about the audible frequency??
ssanmor 3rd October 2006 05:56 PM
No, ackcheng, what I meant is that the SPS80 didn't add audible noise to the amplifier. Any amplifier has a background hiss, that in the case of BP4078 is only audible when all is absolutely silent and you put your ear next to the tweeter. (in the order of 100dB s/n)
Of course the switching frequency is well above the audible band, but sometimes with Class-D amplifiers, the amp and supply freqs. "beat" and move to the audible band. This is not the case with SPS80 and Bp4078 (and according to our customers, not with UcD180/400 or zappulse either).
Rich,
I didn't want to understate the s/n ratio of tube amps, what I was saying is that in theory you are in worst conditions using SMPS with switching amplifiers, for the reason stated above: beating frequencies that may produce "whistles" or colored hiss.
In tube amps you don't have these effects. This doesn't mean, as you pointed out, that you must be exquisite with the wiring (as you have to with other kinds of amplifiers).
In any case, a very interesting mix: I am anxious to hear what our tube customers report about using our SMPS with their amps!
I must confess to be a tube ignorant, by the way.
Sergio
richwalters 3rd October 2006 07:56 PM
Sergio
-->Tube ignorant ..... Doesn't matter......However, one can get birdies, whistles with tube amps. More than one suspects. The common high slope ECC88 RF tube is a good example. I use it in my preamp output. Badly wired and sloppy decoupled, it will peacefully oscillate at low levels around 100-400Mc/s and this will intermodulate with any audio signal passing through and one wouldn't know about it. The cathode follower is a particular configuration that can cause this. The remedy is simple.....use a screening can and better layout.
Noticing your comment.......in days gone long past it was common design practice in tube tuner mixer oscillators simply to put stub of wire from the oscillator close to the mixer tube grid pin in question.....and mixing happens.
The statement--> in tube amps doesn't has this effect.....quite wrong. If you look at a standard tube amp with global neg feedback, notice one of the output transformer sec windings returns via resistor and cap (or step filter) to the input tube cathode. The speaker wire inductance/ impedance is high relative to RF and can pass strong AM signals back into the first stage. Demodulštion can take place and one hears the radio in your speaker. This is the so-called problem of CB radio "busting" through stereo systems.
richj
ssanmor 3rd October 2006 08:00 PM
I take my hat off, Rich. As I said.... I am a tube ignorant. They weren't even in my textbooks when I studied electronics...
Still very interested in knowing how our supply works with tubes.
cerrem 4th October 2006 08:16 PM
One thing to keep in mind...
SMPS have gotten a bad rap..and for good reason....
Most of the textbooks on switchers are way outdated with 1980 technology...as well as many SMPS engineers are outdated and clueless as well.....
It is very possible to design high efficiency, low noise SMPS...
Especially making them low in EMI .....
The use of a properly stabilized Quasi-Resonant switcher at or above 500kHz will work out really well for audio applications..
Chris
Copyright ©1999-2017 diyAudio
