need help understanding voltage regulator schematic (using CCS) from Raleigh Audio - Page 3 - diyAudio
Old 29th September 2006, 03:42 AM   #21
jarthel is offline jarthel  Australia
Originally posted by poobah
Right... the "new" resistor is what drops the voltage down to your desired regulated voltage.
In order to calculate the 3rd resistor, you need to know your max and min load current... and the raw voltage, and the regulated voltage.
if all I need is resistor to drop the voltage, then what is the purpose of the TL431 circuit? is it to keep the output voltage constant?
Old 29th September 2006, 11:08 AM   #22
ianc13 is offline ianc13  United Kingdom
Hi jarthel,
You are correct that the TL431 keeps the voltage constant. Basically it does this by either drawing more or less current to keep the voltage that it uses for comparison equal to it's own intenal 2.5V reference.
By drawing more or less current there will be a corresponding change in voltage drop across the '3rd resistor'.
There is a good article about this at tubecad.com, see the following PDF:
TubeCad Journal Shunt Regulator
Happy building
Help with schematic understanding sumo Tubes / Valves 6 2nd May 2009 11:07 PM
Raleigh Audio Preamp - somebody heard ? dejanm Tubes / Valves 4 14th January 2008 01:15 PM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 03:09 AM
irf610, irf9610 voltage regulator schematic needed for +/-15V sunrise Solid State 4 22nd June 2006 08:57 PM
Help Understanding CD Player Output Voltage, etc. Stew Digital Source 5 26th February 2006 02:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
