| diyAudio Sponsor | ||
I found some Haltron (England) NOS 5687 tubes in a local shop, at a low price: are they good? Can be used to drive a SE KT88? Ciao, Giovanni
In Nomine Libertatis Vincula Edificamus, In Nomine Veritatis Mendacia Efferimus. |
#2 |
Only last night I was listening to a 300b SET using 5687 in two stages as input and driver, and it sounded fine. I believe the 5687 has been used in a few high end SETs, even by Zander if my memory is correct. Don't have any schematic links, but I'm sure others will oblige.
#3 |
Thanks for the answer.
Another question: the same shop has some russian (no brand) 6N6P/ECC99, what about these tubes?
#4 |
Those, too, are fine tubes. A Russian tube to keep an eye out for is the 6N30/6H30. Look what they use in in the finest tube amps out there, like those by Ken Shindo. Usually that's a pentode. But when triodes are used, it's frequently low Ra triodes.
#5 | ||
I use both of these tubes with a plate load CCS as a gain stage for a DAC with passive I/V (http://www.ecp.cc/5687_module.html) and both work very well. |
#6 | |
russian doble triode 6N6P sounds much better!
Audio Researcher Daniel Petrov also known as widowmaker |
| 5687 and ccs? | mark_titano | Tubes / Valves | 75 | 11th March 2006 10:09 PM |
| 5687 dc 5687 tube amp need help | vangogh-hk | Tubes / Valves | 8 | 4th January 2006 12:09 AM |
| 5687 pre? | sparkle | Tubes / Valves | 13 | 15th July 2004 05:10 AM |
| 5687 Tube - best choice | Alfetta87 | Tubes / Valves | 5 | 7th May 2004 02:25 PM |
| 5687 | Alastair E | Tubes / Valves | 7 | 18th March 2004 09:37 PM |
| Page generated in 0.09133 seconds (73.27% PHP - 26.73% MySQL) with 10 queries |
