diyAudio Sponsor
Old 24th September 2006, 05:07 AM   #1
Default Rectifier question
Hi and sorry for the noob question.
Im looking to build an amplifier that calls for a 5U4 rectifier. A friend gave me two GZ34.
Can a GZ34 replace a 5U4 without modification to the circuit ?
Where can I find documentation on each of the tubes ?
Old 24th September 2006, 05:33 AM   #2
jarthel is offline jarthel  Australia
Default Re: Rectifier question
gz34 has less max voltage and current limits. so it may work. it may also not work. read up on the datasheet and compare.
ps. most b+ schematics would state the voltage output but not the current. so you may find that voltage wise, it's okay but when you power it on, a single gz34 won't be enough. you can always use always parallel 2x gz34 to make sure you have enough current.
Old 24th September 2006, 05:47 AM   #3
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Look here http://www.tubedata.info/
Old 24th September 2006, 07:04 AM   #4
max29 is offline max29  Netherlands
http://tdsl.duncanamps.com/show.php?des=5U4
very accurate and detailled information as well and much much more there to spend some time on..
Old 24th September 2006, 08:26 PM   #5
Thanks for the datasheet links
Diodes On Rectifier Question Trout Tubes / Valves 17 14th May 2008 04:25 PM
Vacuum Rectifier Question Eli Duttman Tubes / Valves 16 3rd January 2008 11:52 PM
SD05 rectifier question stef1777 Parts 1 21st February 2006 08:48 AM
Rectifier design question Svetlana Pass Labs 1 29th June 2004 03:11 PM
Page generated in 0.07808 seconds (80.20% PHP - 19.80% MySQL) with 10 queries
