How to reduce gain of this Tube Preamplifier ?
Old 21st September 2006, 06:42 PM   #1
ANALOG GUY is offline ANALOG GUY  Malaysia
Send a message via MSN to ANALOG GUY
Question How to reduce gain of this Tube Preamplifier ?
I search about method to reduce gain of this Preamp (They're called CAT SL1 ?) 12AU7 plate load + 12AX7 mu stage + 6DJ8 cathode follower.
When I built this preamp it has a lot of gain and hum on the output, gain of this preamp = 20K/1K = 20dB ?
When I connected to osciloscope its responsibled curve is flat only 40Hz - 12KHz
Regard
analog guy
Old 21st September 2006, 06:51 PM   #2
phn is offline phn  Sweden
phn's Avatar
I would think the gain is closer to 26db!
I would scrap it and build the Aikido instead. You have all you need to build it and it will reduce gain to about 18db.
Old 21st September 2006, 07:26 PM   #3
jane is offline jane  Norway
jane's Avatar
One way is to decrease the value of the 20k feedback resistor from the cathode of the CF back to the input stage, but then you probably have to recalculate the working point for the input stage.
Another strange thing: The grid of the lower 12AX7 in the mu-follower is floating; you should connect the grid to ground via a resistor.
Jan E Veiset
NO-6600
Life is hard - Then you die.
Old 21st September 2006, 07:37 PM   #4
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
If you want to maintain the original schematic , you can put a 20K resistor in series with a electrolytic capacitor, in parallel the original 20K feedback resistor.
That way you cut the gain in half.
Originally you have 21X and with the mode 11X...
Jorge
Old 21st September 2006, 11:47 PM   #5
ilimzn is offline ilimzn  Croatia
Oh dear. Mu follower with an AX7 in a preamp, why all this gain? Bottom AX7 has a floating gate (probably a drawing error. Also the cathode load of the output stage shares function with feedback network and influences input bias. All in all, I think one could do a better preamp with half of the same parts!
Old 22nd September 2006, 04:37 AM   #6
Yes, it's a really SL1 cloned schematic but I don't know why they're design in this way.
Maximum output is 50V !!! sound not clear, not smooth, less airy, too sensitively with hum !?!
Please comment in my newer idea : change Rp of 12AU7 to 150K to decrease gain and current, add Rg 1K and 475K to ground for bottom 12AX7, decrease 6DJ8 output capacitor from 10uF to 4.7uF but why they used only 47K for output impedance ?
I still confuse for this schematic if anybody had modified them please tell me for your modification
Thanks for advance
analog guy
How to reduce gain of this Tube Preamplifier ?Hide this!Advertise here!
Have to calculate gain for typical small JFET preamplifier supernet Solid State 4 12th August 2006 12:22 AM
Is there a no/gain preamplifier schematic using high-distortion EC90? Layberinthius Tubes / Valves 6 10th May 2004 07:13 AM
Reduce Input Gain Question? mgreene Chip Amps 9 27th April 2004 12:32 PM
tube preamps and gain bonsai171 Tubes / Valves 3 14th March 2004 01:13 AM
Copyright ©1999-2017 diyAudio
