diyAudio Sponsor
Old 21st September 2006, 02:45 AM   #1
jarthel is offline jarthel  Australia
Default M6 lamination: what is it?
I found the word in eletra-print's catalog.
I've search here and the net for some reference info on M6 lamination. Unfortunately, I didn't any helpful results.
an explanation or a URL would be most helpful.
thank you.
Old 21st September 2006, 04:05 AM   #2
Geek's Avatar
M6 is a grain oriented silicon steel.
The anneal is also very important, as it affects the permability as well as the BH curve linearity and power handling. Longitudal anneal is used in output transformers, while random or no anneal is often used in power transformers, because it's cheaper.
M4 is sometimes used for high-end stuff, because of the better magnetic properties, leading to a more efficient and smaller transformer. Rarely used, because it's about double the cost of M6. A well designed M6 transformer makes the M4 advantage almost moot, too.
Sorry, I don't appear to have a decent link
Old 21st September 2006, 04:11 AM   #3
but your explanation more than made up for the lack of link.
thank you very much
Old 25th January 2012, 02:53 AM   #4
CRGO Strips India, CRGO Transformer Laminations, CRGO Core India
Murray
Old 25th January 2012, 03:11 AM   #5
Jacques Merde's Avatar
Also: http://www.aksteel.com/pdf/markets_p...d_Bulletin.pdf
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 25th January 2012, 08:36 AM   #6
Alain Poitras's Avatar
Originally Posted by Jacques Merde View Post
Thank you Jacques M ... It is very interresting !
Lamination Size ak_47_boy Tubes / Valves 30 23rd April 2007 02:57 AM
Ultra Hi-B 0.03mm lamination start to supply tube-lover Group Buys 5 25th February 2007 04:55 PM
Page generated in 0.09414 seconds (77.29% PHP - 22.71% MySQL) with 10 queries
