diyAudio Sponsor
Old 21st September 2006, 02:52 AM   #1
Dylanl is offline Dylanl  United States
Default DIY tube preamp kit
I would like to purchase a tube preamp kit to pair up with my Dynaco Mark 3's and Klipschorns. Does anyone know if one is out there and one that would compliment this setup.
Old 21st September 2006, 02:59 AM   #2
Try www.avahifi.com Frank VanAlstine. I bought a cheap dynaco pas3 and then purchased his kit to rebuild.
Old 21st September 2006, 03:12 AM   #3
I have read many nice things about the Foreplay III from Bottlehead. The Bottlehead products have a big following and an excellent support forum.
Bottlehead Foreplay III
dg
Old 21st September 2006, 06:18 AM   #4
I currently have a pair of Pam1 or Pas1 as some call them but they have a tendancy to hiss and the volume pots do not match at all. I have had a tech locally look at them and make a few mods but they still hiss. Some have told me that this is a good set of pre amps but I like building and if I could make one better I would like to. I also would fix these if I knew how.
I like this site lots of talented people here.
Old 21st September 2006, 12:31 PM   #5
Sell or trade them for a dynaco pas 3 . Get franks kit and you will have a great tube preamp. His kit replaces everything inside except the transformer, selector switch's , jack set and on-off switch. Tone controls are not used anymore and your volume and one other pot is replaced with Alps brand pots. YOu can purchase his jack set replacement (which I did) and the ceramic selector switch (which I did not) made my own. Alittle high in price but well worth it. I will tell you that I am in no way affiliated with Frank VanAlstine. This is just my opinion, I'm sure there are other fine tube kits out there.
Old 21st September 2006, 11:09 PM   #6
Thanks, I will look into them. Any others than that kit that are proven?
Old 21st September 2006, 11:37 PM   #7
dsavitsk's Avatar
http://welbornelabs.com/ultraintro.htm
http://diyhifisupply.com/diyhs_basie.htm
http://www.hagtech.com/clarinet.html
Old 23rd September 2006, 06:53 AM   #8
Does the CARY AE3 replica have a regular volume control or a stepped volume pot? I don't like the stepped.
Old 23rd September 2006, 12:37 PM   #9
zacster is offline zacster  United States
Not a kit but a lot of people are building the Aikido by John Broskie. Check tubecad.com for info, or just check this board. I'm building one myself. It does require more than just what he sells, such as a chassis and power supply, so you need to have some knowledge of putting things together.
Old 23rd September 2006, 06:22 PM   #10
Geek's Avatar
Broskie has PCB's available through his site. http://www.tubecad.com
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 07:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 05:28 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.10485 seconds (74.85% PHP - 25.15% MySQL) with 10 queries
