1st cap heats up...
1st cap heats up...
Old 21st September 2006, 02:38 PM   #11
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
a 4.7 uF cap is small amd may have a high ESR, causing heating. A larger cap won't have that problem, but may increase peak current too much for 5Y3. If you remove the cap, you'll have to decrease the value of the first resistor to keep the same voltage (should be at least 2W, since it now has to carry ripple current...). The RCRC filter that's left SHOULD have have enough ripple attenuation...
Old 21st September 2006, 05:33 PM   #12
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
1st cap heats up...
exactly what I did. the frist R was reduced from a value of 1.8K to 470R to maintain 320V at the junction of the tube and first resistor.
1st cap heats up...Hide this!Advertise here!
kenwood excelon amp over heats to 203F mattsoft Car Audio 4 21st September 2005 12:54 PM
External screen heats up tranformer rapidly Bas Horneman Parts 7 13th July 2005 08:06 PM
Copyright ©1999-2017 diyAudio
