diyAudio Sponsor
Old 21st September 2006, 12:12 AM   #11
poobah is offline poobah  United States
poobah's Avatar
On second thought that is pretty bundled up... How many secondaries do you have there? You would have to cut all that up until you could see the coils.
The reason I ask... you will not see your final voltage until ALL your secondaries are operating at their target load. The need for resistors, at least an exact value, might be premature.
Old 21st September 2006, 12:15 AM   #12
jarthel is offline jarthel  Australia
hmm when I measured the voltage, I just connected the rectifier tube to the 5V secondary with nothing else connected. It was the same when I checked the voltage for the 6AS7 and 6SL7.
I'm assuming this is not the right way to do it?
Old 21st September 2006, 12:24 AM   #13
poobah's Avatar
Not wrong... but not exactly right... as all the secondaries are loaded up, you will see the voltages lower across the board. So you may not really have a problem.
You know... at this point, you are 10% high, which is within spec (barely). Why not proceed, knowing that you may need a resistor, in other words leave room, and get some more load on the trans? The voltage will come down some more.
Old 21st September 2006, 12:41 AM   #14
thank you for the help. you've been very helpful to me
I'll follow your advice. I'll load up all the needed secondaries first before I buy the resistors
Old 21st September 2006, 12:48 AM   #15
poobah's Avatar
Old 21st September 2006, 04:33 AM   #16
poobah's Avatar
Sorry dude... forgot the "why".
The resistance of the primary winding effectively appears in series with the inductance coupled to the secondary. So, as output power increases, so does primary current. This in turn causes the drop across the primary to grow, and in effect, the primary winds up with less voltage; this in turn, means less secondary voltage.
Old 21st September 2006, 04:45 AM   #17
thanks for the additional info. unexpected but greatly appreciated.
Old 21st September 2006, 04:50 AM   #18
poobah's Avatar
Dropping rectifier filament voltage Nightpuma Tubes / Valves 13 2nd February 2009 10:55 AM
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 04:19 AM
Location of voltage-dropping power resistor hollowman Power Supplies 21 5th December 2008 08:13 PM
Why is my MOSFET dropping so much voltage? arnoldc Power Supplies 19 21st April 2006 07:52 AM
Page generated in 0.09647 seconds (78.29% PHP - 21.71% MySQL) with 10 queries
