Which amp for Jordan JX92S Tline ?
Old 14th December 2002, 05:54 PM   #1
founzie is offline founzie
Default Which amp for Jordan JX92S Tline ?
Hello to all tube specialists,
whet would you recommend to drive a pair of Jordan JX92S (88db) based transmission lines ( similar to Carolina Audio or Konus ones, with some mods that doesn't in my mind affect their relation to the amplifier ).
regards,
François
Old 14th December 2002, 06:44 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default WHAT AMP?
Hi Founzie,
I think that what is said here could also apply to your speakers and amp requirements.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=8578
There is of course plenty to choose from.
If you do not want build from scratch you may be interested in looking at the secondhand market in France.
An Ampliton or Yves Cochet for instance would drive your speakers nicely and with a bit of tweaking can still hold their own to this day.
Ciao,
Frank
Old 15th December 2002, 05:51 PM   #3
Is a 6W single ended enough for a 88db speaker or is a 15W push-pull recommended ?
My room is 4x4 meters but open on one side to a 4x10 meters room (makes a "L").
On my old technics (class H+, 2x100W), the volume control is between 1/4 and 1/3.
regs
François
Old 15th December 2002, 08:39 PM   #4
fdegrove's Avatar
Default WATTS
I would even go for more than just 15 Watts in PP.
If you go for too little power your amps will clip and you won't have great dynamic range (lack of headroom).
Frank
Old 21st December 2002, 12:19 PM   #5
Can anyone send me the URL of a kit maker for a 30W tube amp (KT88 ?). I'm looking for a stereo one with buit in power supply, no integrated preamp.
Seems 15W may be not enough for a 88db speaker.
regs
François
Old 21st December 2002, 01:33 PM   #6
fdegrove's Avatar
Default KIT
Hi Francois,
In France or globally?
Here's is one not too far away from home:
WORLD AUDIO DESIGN
Ciao,
Frank
Old 21st December 2002, 02:34 PM   #7
Brett is offline Brett
Brett's Avatar
15W isn't enough unless you use them like headphones.
15W (or 11.7dBW) gives you 100dB SPL at 1m (90dB at 3m) at clipping. 80dB SPL <i>average</i> is a moderately loud listening level, so 15W only leaves you 10dB for peaks in the music, where IMO 20dB is a minimum or else the music will sound compressed.
Cheers
Old 21st December 2002, 05:31 PM   #8
World Audio has two kits :
one with EL34s (32W per channel)
one with 6550, KT88 compatible (40W per channel)
Both are UL Push-Pull
The second is 20% more expensive.
Is it more reasonnable to go to 40W or is 32W already enough for my 88db speakers ?
Seems to me those are great powers for tube amps...
François
Old 21st December 2002, 05:35 PM   #9
fdegrove's Avatar
Default EL34/6550
I would prefer the one with the 6550 personally.
Not just for the extra wattage,I just prefer the sound of the 6550.
Frank
Old 30th December 2002, 05:57 PM   #10
316a is offline 316a  England
316a's Avatar
Hello ,
I use a SE 6C33 SRPP amp to drive my Jordan JX92VTL , about 10 watts a side . Similar sized room , I use mine in my 10ft x 10ft workshop . The only problems I ran in to : not enough treble over 10kHz (too warm) . Have added ribbon and currently piezo array (4 per side) tweeters . Also I ran my amp parafeed with self bias for a while : not good , changed to fixed bias , ok . Need fairly good damping to tame these fairly reactive tl's . Yet to try with a push pull amp but would expect far better bass , which is already good !
316a
Which amp for Jordan JX92S Tline ?Hide this!Advertise here!
Looking for Jordan JX92S lcsaszar Swap Meet 5 28th December 2013 12:26 AM
CSS fr125 vs jordan jx92s marchel Full Range 7 22nd April 2008 04:17 PM
FS Jordan JX92S JohnnyBoy Swap Meet 0 17th October 2006 10:58 PM
Jordan JX92S Gaffer74 Full Range 11 31st May 2006 09:42 PM
jordan jx92s TL box pstephenson Full Range 3 26th October 2004 12:56 PM
