diyAudio Sponsor
Old 16th September 2006, 07:38 AM   #1
Default Floating the heaters
Hi
I am working on a direct coupled preamp design and was thinking of using a 175v on the plate of the first stage.
I was thinking of using an Ef86 for the second stage which has a 100v cathode to heater max. Can I simply float the heater that far and if so, what voltage would you recomend?
Do I need to make sure that the heater of the first stage is not floated?
Thank you for your insights! Have a great day!
YF
Old 16th September 2006, 11:24 AM   #2
Hi YoungFred
What is the other tube that you are using? If it also has a cathode to heater max of 100V you could float the heater on about 85V, than both heaters will be within their specs (although pretty stressed).
I believe that in this case it's desirable to use separate heater windings. That will reduce stress, other reason is that if the heater is floated below the cathode there is some kind of diode action between both. If you float your heater some 30V above the cathode voltage this is eliminated. So if you can reference heater for first tube at around 30V, and for the second at around 200V.
I am newbee, but if I am wrong others will correct me
Erik
Old 16th September 2006, 11:59 AM   #3
Geek's Avatar
Floating the heater is just fine. Do bypass it with a capacitor (say 2.2 to 4.7uF) to ground for noise considerations. If possible, lift the heater +30V or so above the cathode potential (keep the noise bypass cap too). This is easily done with a divider/bleeder from the supply, as the lift draws no current.
Tube heaters AC or DC? soundbadger Tubes / Valves 105 1st March 2008 11:04 AM
PSU for 12V DC heaters cbutterworth Tubes / Valves 15 9th March 2007 07:25 AM
schematic for 12.6 VDC heaters cbutterworth Tubes / Valves 7 5th March 2007 08:09 PM
centre tap or floating heaters? lt cdr data Tubes / Valves 3 23rd August 2006 07:35 AM
Help with hum in AC heaters HeadSh0T Tubes / Valves 21 27th September 2003 01:40 AM
Page generated in 0.06738 seconds (68.90% PHP - 31.10% MySQL) with 10 queries
