| diyAudio Sponsor | ||
Hello all,
Anyone out there messed with the RCA OTL design? http://www.k-amps.8m.com/cgi-bin/i/P...uum/rcaotl.gif Looks pretty straightforward but something has to be done about that power supply altho having a tube amp without any iron is an interesting idea. maybe hide away an isolation transformer somewhere. Speaking of transformers curious of others experiance repurposing 400 cycle transformers for 60 cycle use? Ive tried a couple for the heck of it 120V on the 130V tap. The idle current seems a bit high but not seeing any signs of core saturation or overheating at ~rated load. Austin |
#2 | |
I think that using a 400Hz transformer on 60Hz will invite the fire gods to dance on your project.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#3 |
nah actually for best results, just switch the primaries for the secondaries to counteract the phase imbalance... fire gods, indeed
#4 |
Parallel the secondaries out of phase
Its too bad about these things some would be really nice transformers if they were for 60 cycle. Ive been digging thru an old junkyard and coming up with neat stuff, getting ate up by mosquitos in the process. potted transformers arnt fun to burn up that smell lingers for days. Minus the power transformers these old avionics remotes still have some cool parts and are built like a brick dog house. |
#5 | |
At 60Hz, the 400Hz will have a volts/turn ratio that's way too high. The voltage has to come down at the lower frequency. If the winding is rated at 120Vac @ 400Hz, it'll have to be reduced to 18Vac @ 60Hz. If you try to run it at 120Vac @ 60Hz, it will poof. Either that, or build a 400Hz inverter. |
#6 |
Hi vp36kv ,
Miles Prower is correct . Dont do that !!! When you increase the working frequency of any power tranny , the calculation shows up that you can decrease the quantity of iron on the core . So if you connect a power tranny at a lower frequency ( 60 Hz ) than the specified ( 400 Hz ) , the lack of iron core , will increase the current a lot , then the tranny will overheat and ... ... ( probably ) burn out . Regards , Carlos |
| Loudspeaker magnet and aircraft safety | Ipanema | Multi-Way | 9 | 6th July 2009 07:30 PM |
| Aircraft Fasteners Selling | Dark Shadow | Swap Meet | 1 | 25th March 2009 10:33 AM |
| Audio switch like in aircraft chair arm | tmd1 | Parts | 0 | 29th June 2006 12:38 PM |
| Military aircraft reminiscences | BobEllis | Everything Else | 12 | 23rd June 2006 07:25 AM |
| End of a long and beautiful aircraft story | Netlist | The Lounge | 7 | 26th October 2003 03:03 PM |
| Page generated in 0.09770 seconds (75.85% PHP - 24.15% MySQL) with 10 queries |
