diyAudio Sponsor
Old 14th September 2006, 04:15 AM   #1
dsavitsk's Avatar
Default James Transformer BS
On one side, my James transformers have a 0, a 4 ohm, and an 8 ohm pin which is straight forward enough. On the other side there are 3.5K and 5K pins, which makes sense, and a B pin and an S pin. Anyone know what these are?
Old 14th September 2006, 09:17 AM   #2
dmcgown is offline dmcgown  United States
If I were to guess, B would refer to the B+ connection and S the screen connection for ultralinear connected pentode. You can use an ohmmeter across the windings (either 3.5K or 5.5K taps) and confirm the B connection is higher in resistance than S.
Old 14th September 2006, 09:24 AM   #3
Geek's Avatar
I thought this was going to be a rant thread
Old 14th September 2006, 10:53 AM   #4
pmillett's Avatar
The guess above is correct.
There's a datasheet here:
http://euphoniaaudio.netfirms.com/ea...f/6113-25K.pdf
Assuming this is the one...
Pete
Old 14th September 2006, 11:12 AM   #5
diyAudio Moderator Emeritus
ray_moth's Avatar
Ha!
Old 14th September 2006, 01:29 PM   #6
yes I think that's correct, the b connects to your psu, and the s is indeed screen, try both the 3k5 and 5k and see which you prefer, also try reversing the b going to the tube and the 3k5 to your psu and see which you prefer, its optimised the correct way for capacitance, but you may or may not prefer t'other way around, won't do any harm
Old 14th September 2006, 03:11 PM   #7
JojoD818's Avatar
that was my first thought too regarding the title.
I hope it's ok to ask but if I have an output tranny which I know is for an EL34 in PP and I know the B+, UL taps, and plate taps. but I don't know which is 0, 4, 8, 16... how could I check that? my DMM cannot measure any resistance in the speaker side.
Old 14th September 2006, 05:14 PM   #8
dsavitsk's Avatar
Pete
Thanks Pete, I looked all over for that.
I think you could hook up a resistor across the primaries and then measure different resistances on the secondaries.
Old 14th September 2006, 05:24 PM   #9
SY's Avatar
CAREFULLY apply a high AC voltage (100V through a Variac would be ideal, but 220V mains will work) to the primary, then measure voltages at the secondary. No loading needed.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th September 2006, 05:25 PM   #10
Hi JojoD
I think you could also apply a (small) voltage to the primary and measure the secondary. The highest reading would be for the 16 ohms, the lowest for the 4 ohm...
Or juist build an amp and try to find out which is which listening to the amp...would make a nice blind test, I think
Erik
Simple SE output transformer: James or Edcor? dogfish Tubes / Valves 8 12th June 2009 10:23 PM
james 6123hs totaltech Tubes / Valves 4 29th August 2008 11:21 PM
Fun with James Nixie The Lounge 2 1st March 2007 06:13 PM
Hammond vs. James? Sherman Tubes / Valves 56 26th July 2006 01:30 AM
James Singapore okkyn Tubes / Valves 4 3rd February 2006 12:39 AM
Page generated in 0.10794 seconds (80.76% PHP - 19.24% MySQL) with 10 queries
