| diyAudio Sponsor | ||
Is it possible to use break before make switches as stepped attenuators (volume controls), or is there a bang between switch contacts as the switch goes open circuit? How does this work in practice - is it unuseable or not, and are there any work-arounds? Andy
#2 |
You can use a resistor at the common pin to the ground. So you always have a load than at the input of your amplifier. Than there is no floating signal.
#3 |
If we label the three connections on the attenuator input, wiper and common, then this is a resistor from common to ground? But this would prevent the attenuator from shorting out to ground, i.e. going completely off?
I can see two scenarios here a) conventional SE attenuator as above b) shunt attenuator in balanced mode, which is just a single series of steps between plus and minus Is either of these easier to achieve? In the latter, with no resistor in circuit it would be open circuit i.e. max volume. |
#4 |
No it wouldn't prevent the attenuator from going all the way to ground. It is in parallel with the attenuator output.
Incidentally this resistor should be as high as you can safely make it to avoid loading the attenuator. Say in the case of a 100K to 250K attenuator something like 1M ohm.. (Depends also on the safe maximum grid resistance for the input tube you are using.)
www.kta-hifi.net |
#5 |
On second thoughts, the "common" referred to must have been the wiper.
#6 |
If you build an attenuator as shown in the drawing there will be no clicks or pops if a break before make switch is used.
The example has only a few steps to illustrate the concept. I've built one with 1 dB steps and I would probably go with 1.5 dB steps if I did it again. Of course not all the steps have to be the same size, near the bottom I made each step bigger so my last step was 10dB (40 dB total attenuation) |
#7 |
Many thanks for the schematic - looks like BBM is a possibility. I'll have to try it. Andy
| FS: 2x Dact 50k Stereo Stepped Attenuators | LastStop | Swap Meet | 1 | 15th December 2005 09:44 AM |
| FS: 2 - 10k Balanced Stepped Attenuators (4-gang) + more | LastStop | Swap Meet | 2 | 6th November 2005 07:01 AM |
| FS: DACT CT-2 10K Stereo Stepped Attenuators | antness | Swap Meet | 9 | 4th March 2004 05:13 PM |
| Alps Stepped Attenuators on Ebay | Shoog | Everything Else | 0 | 11th April 2003 07:10 PM |
| stepped attenuators? What should I get from the ff. choices? | jarthel | Solid State | 9 | 3rd July 2002 12:24 AM |
| Page generated in 0.09688 seconds (73.90% PHP - 26.10% MySQL) with 11 queries |
