6C33B-C push pull with output transformer
Old 5th June 2009, 06:49 PM   #21
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Important with the big Russian '33 to Burn-In BEFORE attempting any matching....
To burn-in-
Run heaters Only for 24-48 hours.
heaters off, cool down for hour or so.
Then heaters On, only for half-hour.
Then arrange PSU of 60-80V etc, to pull 600mA with small neg on grid, to control current--monitor over first hour and trim G1 to maintain 600mA.
Leave for 2-3 hours drawing full current.--they get Bloody HOT!!-caution!
Kill B+ and then heaters, leave to cool completely and Then do your matching--BUT Remember, 6C33 Must be warmed up for around Half-hour with +B before taking any readings....
Time consuming process but pays out in life and less drift/stays matched issues....
Das Beste Oder Nichts
Old 27th December 2017, 04:58 PM   #22
Tyimo is offline Tyimo  Hungary
Hi!
What about to use Garter bias?
Shoog you are an expert in it! Is it possible?
Greets:
Tyimo
"Replacing any coupling capacitors with a well designed and correctly matched driver or interstage transformer yields an almost shocking improvement in sound..." Peter Qvortrup
Old 27th December 2017, 07:12 PM   #23
goldenbeer is offline goldenbeer  Germany
Garter bias with low mu triodes is no fun. Big time energy waster...
Old 29th December 2017, 09:07 AM   #24
Old 3rd January 2018, 06:43 PM   #25
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
I've done it and actually really, really like it. 165v supply, two 6AS7G in push-pull, and 330R cathode resistors each in a garter bias configuration. Works great, excellent balance, and sounds fantastic. Ignore the power consumption and excess heat. takes 33v or so each grid for full output, so 12AT7 or 6SL7 concertina works well, with headroom for negative feedback. This rig with 6SL7 up front is actually one of my favorite amplifier setups for low-moderate output uses, such as small bedroom rigs or similar. Efficiency be damned, as it sounds great and measures very respectably.
Only tricky part is getting 300~320v or so for the driver stage, which works fine with a dual ~115v secondary isolation transformer, just rectify each output and stack them on top of eachother. I've got a cheap isolation toroid that I simply added a set of 6 volt filament windings to, and it works great, and is cheap.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
6C33B-C push pull with output transformerHide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
laying out dual output push-pull transformer? zilog Power Supplies 0 2nd September 2008 08:50 PM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 09:48 PM
Push Pull Output Transformer wiring problem cyl Tubes / Valves 8 25th April 2007 02:23 AM
Transformer coupled 6SN7 push-pull DAC output stage? cathode_leak Tubes / Valves 7 24th January 2005 07:26 PM
