| diyAudio Sponsor | ||
Someone on the forum suggested that MOT's (Microwave Oven Transformers) can be used as plate chokes.
I have just finished converting my RH807 parafeed amp from a CCS load to a MOT choke load. So in the specific case of my setup, ie 50mA DC current 330V plate load and a low output impedence output stage, - it works a treat. Response is good down to 10hz and up to 35khz where it starts to roll off. All I did was disconnect the stud mount where the HT secondary is connected to the earthed core of the transformer. Take this connection and wire it in phase and in series with the primary winding. I also tried removing the primary winding (aluminium wire - and very difficult) and the shunts, but it made no noticable difference. So if you fancy trying your hand at a parafeed design but are scared off by the price of plate load chokes - give it a go. What have you got to lose but about £200 for some plate chokes. Shoog |
#2 | |
Hi Shoog
Nice to read this works! As always I would like to try, someday I will have the time (university, job, house and girlfriend take lots of my time). But just a question... Quote:
Erik |
#3 |
Another thing we can start to disembowel
The real difficulty I think is to find a pair of identical trafo's, unless ofcourse there are only a handfull of models manufactured by a few companies for the whole microwave industry... Where did you get your pair, shoog? Simon |
#4 |
I removed the primary from one of the MOT's just to see if it helped. It didn't so the other has the primary in series with the secondary. Its not absolutely necissary to wire them in series, but I hate to leave a coil unterminated just in case of ringing.
I got mine from the local council recycling center. When I went there were about 6 of the same model of microwave. They tend to come in like this because some shop does a special offer on a particular model, everyone buys them and then they all fail at about the same time. I'am not certain absolute matching is critical. They all tend to come in 800W or 900W models and will all be fairly similar. Shoog |
#5 |
Wow, got a pic? I've always been fascinated by those 3" thick lams in the big ones.
#6 |
Thanks for the reply Shoog!
Erik |
#7 |
2 or 3 Flouroescent Light Balasts in series also work a treat. They are usually around 3H each.
Cheers, Ian |
#8 |
Hi there,
There are so many TF transformers, chokes, tubes resembling from military machines in my place. Sometime, I bought some transformers and chokes, esepecially I like chokes much. But with the things I bought I didn't know how many henrry they are. So does anyone here know how to measure the henrry of a specific choke? |
#9 | |
I resemble that remark.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#10 | ||
If you put a fixed capacitor(say 0.1-1uf) in parallel with the choke and then feed in a range of frequencies. One frequency should produce a resonant hump in the response. There is then a formula that allows you to feed in the frequency of the resonance, the value of the cap and pull out the henries of the choke. This will give you the static inductance. If you want the real world inductance you will have to pass the expected current which the inductor will be required to pass. Inductance drops with increased current. Here is the formula: F= 1/(2*Pi*x) x=the square root of (L*C) F= resonance hz L= Inductance Henries C= Capacitance farads You will need to rearrange the formula to get the inductance, but I don't trust my maths. Shoog |
| Plate Choke SRPP…. What do think? | sgerus | Tubes / Valves | 22 | 20th January 2009 08:18 PM |
| Plate Choke calculation | swordsman | Tubes / Valves | 7 | 8th April 2008 12:42 AM |
| PP plate-choke? | revintage | Tubes / Valves | 4 | 28th June 2007 11:59 PM |
| using a plate choke? | Raj1 | Tubes / Valves | 15 | 5th June 2005 07:36 PM |
| Plate choke for audio use | sugano | Parts | 0 | 28th May 2004 10:04 AM |
| Page generated in 0.11823 seconds (82.09% PHP - 17.91% MySQL) with 10 queries |
