diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   schematics for a EL509/ EL519 PP amp needed (http://www.diyaudio.com/forums/tubes-valves/8623-schematics-el509-el519-pp-amp.html)
NotInTheMafia 13th December 2002 04:28 AM
Hello,
I was origionaly going to biuld a stereo SE el509 amp, but decided that i would like to build a PP amp instead. I can't seem to find ny el509 pp schematics. Any one know where i can find one? I dont want anything toooo complicated, i dont need ballanced inputs, and dont want OTL schematics, as i only have 4 of these tubes.
--Tom
dhaen 13th December 2002 09:31 AM
Try searching also for schematic +
PL509
EL519
EL519
KT90
All are similar,
Colt45 13th December 2002 01:06 PM
6P45S is pretty close too.
Bas Horneman 13th December 2002 01:07 PM
Hifi News has got one...
designed by Tim de Para... I can scan it for you if you like..
dhaen 13th December 2002 01:14 PM
Bas,
Is that the "enhanced triode" one? Where the signal is input to G2?
Bas Horneman 13th December 2002 01:15 PM
Yes, but I just realized ....that it is a SE amp and not PP...
Colt45 13th December 2002 01:16 PM
I searched around, and I can only seem to find SE
If I get bored enough I might draw up a AB scheme after school ;)
JohnR 13th December 2002 01:21 PM
There's one in Bruce Rozenblit's second book... if you don't mind a 700V plate supply...!
JohnR
Brett 13th December 2002 01:32 PM
PL509
EL519
EL519
KT90
All are similar,
I'm not sure a circuit for the KT90 will work well with the EL519 or vice versa as they are not similar tubes according to EveAnna Manley.
http://db.audioasylum.com/cgi/m.pl?f...ey&r=&session=
Just FYI
I'd like to try some KT90s one day. They have an excellent reputation and are $US140/matched quad
dhaen 13th December 2002 03:07 PM
Thanks Brett, I stand corrected.
Now how did I get that misconception:xeye:
Resources saved on this page: MySQL 18.75%
