| diyAudio Sponsor | ||
Hi DIYAUDIO Friends,
This is mine buffer with 6sn7. There are a CCS with BC547C transistors. I'm thinking to put in on the output of the TDA1543. And the output on mine amplifier with 10x of gain and OPA627 for mine SENNHEISER HD580. Is a GOOD idea put a CCS with transistors on mine buffer? I think the CCS with transistors is more linear than resistors. Is this good? Thanks, Felipe
Brazilian Tube Amp Builder. |
#2 |
CCS loading of the cathode works very well. You'd probably want to run more current through the 6SN7- it's happy at 8-10mA. Understand that the effective load for the tube will be dominated by what it's driving- the CCS will just keep all the DC conditions stable.
You probably don't want to use a 100uF output cap!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
Is it a good idea put more current through the 6sn7GT?
If I put TWO Triodes on Parallel, CAN I drive a Sennheiser HD580? I'm thinking to make only a buffer to drive mine head-amp, but if this buffer have low output impedance to drive a 300ohm headphone, it will be GOOD! VERY GOOD! In the new attach, you can see the new version of this file. =] Thanks, Felipe
#4 |
This is other simulation with two triodes on parallel, a 21mA across the tubes and negative voltage on the CCS.
With a 300R on the output, I saw 25mW ~ 30mW on the Transient Analysis of the Circuit Maker. This is very good for a Sennheiser HD580 or other 300R impedance Head-Phones. Best Regards, Felipe
#5 |
You're probably going to want to reference the ccs to a negative supply to assure you have enough voltage headroom real world. Either that or lift your grid well above ground potential with a resistor bias string and a coupling cap to your signal source. As implemented I doubt this thing can swing more than a couple of volts peak to peak and is highly assymetrical. (As designed the cathode cannot swing below ground whereas the grid can be driven quite negative relative to the cathode driving the tube to cutoff.)
I doubt it would drive a pair of headphones too well either due to lack of current and excessively high source impedance.
www.kta-hifi.net |
#6 |
Kevin,
Why you are asking me to put a negative voltage and lift the grid? Can you draw your idea? I'm isn't understanding what you're speaking. Best Regards, Felipe
#7 |
I am posting a schematic by steve bench to show what Kevin is saying.
http://members.aol.com/sbench101/Crossover/xover.gif R2 and R3 are biasing the grid to about 75V (half B+). That means that the cathode is at approximately 75V too...it can swing lots of voltage (almost from 0 to B+). Erik |
#8 |
Erik,
Your image isn't opening in here. There are other idea to driver the HEADPHONE. I can make two outputs, in the frist, is the output on the tube. The second output is the Headphone output. With a BUF634 buffer or other hi-grade op-amp for 1 gain. This is my new schematic. The output op-amp is a BUF634. ( I think i can use a best schamatic in this part ) The power supply will have many CRCRCRCR stages. Best Regards, Felipe
#9 |
Hmm... in this case the tube is there to add that nice 'tube sound'? If you do this I would use bipolar supply, that saves an input capacitor. And preferably just a resistor on the tail of the CCS, you know, those transistors take all the fun, I mean the tube sound, out.
Erik for an example of a bipolar supply, with resistor to set current, look at http://www.glass-ware.com/tubecircuits/6dB.gif |
#10 |
Yes Erik. The tube will put the tube sound on mine head-amp.
I need a simple buffer. I haven't a dual rail. Best regards, Felipe
| Diamond Buffer - Super Buffer | peranders | Solid State | 34 | 16th May 2010 01:46 PM |
| 6SN7 CCS | Cassiel | Tubes / Valves | 25 | 14th February 2006 10:09 PM |
| 6SN7 based tube buffer | sugano | Tubes / Valves | 17 | 23rd May 2005 01:56 PM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 06:50 AM |
| PSRR For 6SN7 Buffer? | G | Tubes / Valves | 6 | 24th November 2002 12:37 PM |
| Page generated in 0.11671 seconds (78.31% PHP - 21.69% MySQL) with 11 queries |
