diyAudio Sponsor
Old 8th September 2006, 04:33 AM   #1
Default Simple Hybrid SE EL84 UL amp.. comments please.
thinking:
1:1 input transformer -> source follower mosfet -> 1:10 step-up -> 6 to 8 parallel EL84's SE UL.
Running 300v 39mA a piece. maybe a 600:8 output tranny.
fixed bias on output stage to secondary of 1:10.
very simple... no coupling caps.. all major voltage gain by 1:10 and output stage.
power supply: cap multiplier circuit. suggestions?
DC on EL84 filament supply.
comments? suggestions?
will this work and what should I look out for?
thanks!
It is not you... you are it.
Old 8th September 2006, 02:00 PM   #2
rdf is offline rdf  Canada
rdf's Avatar
If it were me the first consideration is confirming a 1:10 doesn't balk at driving the grid capacitances of 8 parralled el84s. Have you considered a source follower, maybe DC coupled, to the el84 grids and using the 1:10 as the input stage? Drops one tranny, replaces it with a smaller signal, higher quality unit and the follower will better drive the output. Since you're going fixed bias you already have a negative supply handy.
Old 10th September 2006, 11:04 AM   #3
I would not go to the complication of dc EL84 heater supply. If the heater wiring does not go near an input, you will certainly not get interference from 6VAC (which I presume is the reason for dc).
Simple EL84 amp... Skorpio Tubes / Valves 11 3rd January 2009 08:25 PM
Tube/MOSFET hybrid results/comments/suggestions? lgo51 Pass Labs 59 22nd June 2008 04:02 PM
Simple EL84 Mas Penk Tubes / Valves 25 17th August 2006 01:55 AM
Simple AMP Comments. arte Solid State 15 26th April 2005 07:49 AM
fs/swop, el84 hybrid tube amp psychosteve Swap Meet 0 11th October 2004 02:10 PM
Page generated in 0.07588 seconds (68.28% PHP - 31.72% MySQL) with 10 queries
