| diyAudio Sponsor | ||
I'd like to understand why the simulation with PSUD does not produce the same values reported in the schematics.
For example ... if I utilize the values reported in the power supply of the 300B stage of the schematic reported below (*)... I do not obtain the same value of V with PSUD. Specifically, I obtain more than 500 Vrms after the 160 uF capacitor, with PSUD... instead of the 385 reported on the original schematic. This aspect recurs also with other schematics. Why ? The only variable thing I include into the simulation is the constant current load that I utilize (at the end of the filter) to test the circuit ... and that corresponds to the current circulating into the circuit (i.e. 85-90 mA in the case of the schematic reported below). Is it correct ? ... or I have to utilize a R load ? ... and if so ... which values to choice ? Many thanks Antonio Tucci (*) http://home.att.net/~chimeraone/axiom300bschematic.html |
#2 |
Just a guess, but I'll bet you're not using the right value for the transformer source resistance. It should be (roughly) DCR of the secondary plus the turns ratio times the DCR of the primary.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
A current source (actually a "sink") is appropriate to use here.
Have you included the resistance of your chokes in the model? Also, be certain to adjust your "reporting" time. People often (me too) look at the start up behavior by mistake... |
#4 |
The DCR of inductors is already reported into the original schematic... and I utilize those values.
As to the time For ... I usually select 10.000 ms, with a delay of 0 sec.
#5 |
OK then....
Set your period to one second, after 10 seconds delay. You are looking at start-up transients. |
#6 | |
Sheldon |
#7 | |
agree; this must be culprit I always find that PSUD is good no less than imported values
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#8 |
I do think start up transients and load steppings are a good thing to look it. Lots of ringing is not good and could make for instability.
Be sure your foil hat has a good low impedance ground. |
#9 | |
Also with those setups ... the results do not change. I have discovered that eliminating the "stepped" option from the load current box ... the Vrms value decreases from > 500V to 363-369 Vrms (according to the DCR value of the secondary of the main transformer ... 31 or 110 ohm). However, these values are still far fom the 385 V. |
#10 |
I need to check out the "stepped option"... you are within 20 volts... that's pretty good.
EDIT... yes stepped load should be OFF. |
| PSUD question | SHiFTY | Tubes / Valves | 6 | 8th March 2008 11:11 PM |
| PSUD II help | Bengali | Tubes / Valves | 10 | 15th September 2007 04:58 PM |
| how to model 125-0-125 in PSUD | cbutterworth | Parts | 2 | 3rd November 2006 03:47 PM |
| Getting my feet wet with PSUD | Saurav | Tubes / Valves | 22 | 26th April 2003 03:12 PM |
| Page generated in 0.10487 seconds (79.11% PHP - 20.89% MySQL) with 10 queries |
