Help me information of the tubes?
Old 7th September 2006, 03:55 AM   #1
bufalo is offline bufalo  Viet Nam
Default Help me information of the tubes?
Hi all,
I just found and bought the two tubes from an old shop thank to their beauty.
There are charaters "TÃ1-2/8 or 0576" on the tubes. I don't know what it is and for what it is used.
Anyone know them and how to use them, pls hepl me?
thank in advance!
Old 7th September 2006, 05:52 AM   #2
I'm sorry, this is my first post. The pictures that I attached don't display.
Someone show me ways to attach them?
Old 7th September 2006, 05:53 AM   #3
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
They should attach now, please try again.....are they smaller then 100kb?
If you can see the speaker cone move...it's not hifi.
Old 8th September 2006, 01:19 AM   #4
Here is the pictures.
I think it is thyratrons not triode. I have no idea about the kind of tube so please give me some advices.
Old 8th September 2006, 01:34 AM   #5
and the datasheet
Old 8th September 2006, 01:47 AM   #6
Geek is offline Geek
Geek's Avatar
Thyratron tubes are like a programmable unijunction transistor (PUT), only on steroids.
I dunno, maybe a class-D project?
Old 8th September 2006, 05:13 AM   #7
gingertube is offline gingertube  Australia
Yes - definitely thyratrons.
While the grid voltage remains at or below 0V no current flows. Put +20V on the grid and the Thyratron "fires" and conducts anode current .
More like an Silicon Controlled Rectifier (SCR).
Max anode volts 8000 volts
Max anode current 6.5A
Max negative grid voltage -100V
Grid Volts for 2A Anode current 20V (max)
Heater Voltage 5.7v min 6.9 V max (6.3 V typical)
Heater Current 5.5A min 7.5A max
Resistance in grid circuit 10KOhm min. 50KOhm max.
Warm up time 2 minutes
Bulb Temperature 250 degrees Centigrade
Typical life 1000 hrs
Thats about all I could "decode/translate" from the data sheet and there may be errors in that (I don't read Russian but recognize a word here or there).
Ian
Old 8th September 2006, 09:33 AM   #8
Klimon is offline Klimon  Belgium
You could build an awesome-looking amplifier with these!
Old 9th September 2006, 02:02 AM   #9
Thanks all of you for the information.
To Klimon,
Can you guide me to build a such awesome amplifier.
As I search on the internet, rythayon generally can not be used to amplify signal linearly. Is that true or false.
I like big tube very much. At present, I'm building a giant amplifier with GU 13 (813 equivalent). So your awesome amplifier make me so interested.
Old 9th September 2006, 02:48 AM   #10
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
You can not build a linear amplifier with a thyratron tube. They were intended as grid controlled switches (the predecessor to the SCR as mentioned) and as such have no linear region. I have several hundred small ones (2D21's) and have found no use for them.
They can be used to make power oscillators, and high voltage trigger switches, so the vacuum tube Tesla Coil crowd may be able to make something with them.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Help me information of the tubes?Hide this!Advertise here!
Some information please ivorthedj Multi-Way 2 18th June 2009 02:00 PM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Information needed on RCA SPECIAL RED TUBES Burnedfingers Tubes / Valves 2 27th April 2007 04:05 PM
Looking for Data/Information on E182CC and 6SN7 tubes wake rider Tubes / Valves 2 3rd July 2002 10:40 AM
