Direct heating triodes are really better? - diyAudio
Old 5th September 2006, 11:55 PM   #1
Jaime is offline Jaime  Uruguay
Jaime's Avatar
Default Direct heating triodes are really better?
The direct heating triodes are really better?.
There are some Web where explains this?
I feel very intrigued by the FI 421A
http://www.6moons.com/audioreviews/fi6/421A.html
best regards Jaime
I write in English worse than Tarzan
Old 6th September 2006, 11:34 PM   #2
Jaime
No reason. On the contrary, there is a varying potential difference between parts of the filament and the control grid, so what is the actual bias? - etc. It is sometimes a little intriguing how, years after some developments have taken place and had been universally accepted as improvements, some visionaries would suddenly pop up and cause doubt as to which direction in audio is actually forward.
The F1 421A certainly looks neat, but I find the description too loaded with typical promotional fodder to mean much. (I mean: "When simple is best, that's the only ticket to bliss in valve land." Please!) Or simply swapping 6SL7s with 6SN7s?? I personally have a problem with exorbitant costing flea-power amplifiers - I built enough of them myself, and never found a good reason for using multibuck ultra-scarce tubage. Unless for collector's value, of course ...... But it is your money.
Regards.
Old 7th September 2006, 01:53 PM   #3
amperex is offline amperex  United States
Usually older direct heater tride power tubes are better. It is the low plate resistance that is desireable in home entertainment amps.
Old 7th September 2006, 02:45 PM   #4
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Now tell me between trioded EL36 and 2A3 (absolutely the same dynamic characteristics) which is better.
Old 7th September 2006, 11:16 PM   #5
Jaime's Avatar
Amperex:
Plate resistance 6AS7G : 280 ohms
Plate resistance 421A : 330 ohms
Plate resistance 2A3 : 800 ohms
You said : 6AS7G and 421A are better than 2A3 ?
Old 8th September 2006, 12:35 AM   #6
kmtang is offline kmtang  Canada
kmtang's Avatar
Hearing is believing.
If you don't believe it, try it out yourself.
I won't say which one is better. It is up to you to decide.
Johnny
Old 8th September 2006, 01:40 AM   #7
SY's Avatar
Or (as I've found), there's no consistent sonic advantage of one over another as a general case. But a DH tube certainly is more of a pain in the posterior to set up and run correctly, which may be its real attraction.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th September 2006, 01:56 AM   #8
Geek's Avatar
"Better" is too subjective in audio. Kmtang and the correct answer
Old 8th September 2006, 04:22 AM   #9
vax9000 is offline vax9000  United States
I believe DHT is better. the low impedance and high linearity combined, is better. 6AS7 has very bad linearity.
My theory:
DHT are old; thus primitive tech; thus big distance between cathode and grill; thus better linearity.
newer diode's problem, newer tech; thus closer cathode and grill (for higher amplify factor); thus worse linearity.
If we can move the grill of new triode away from its cathode, we may get a triode that is better than those old DHT.
Old 8th September 2006, 04:50 AM   #10
rdf is offline rdf  Canada
rdf's Avatar
How so?
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 05:43 PM
KRK V88 Over heating problem Tom7227 Chip Amps 3 9th August 2008 02:49 AM
Best low-signal direct heated triodes? gentlevoice Tubes / Valves 7 5th May 2008 04:03 AM
heating kathodyne Tubes / Valves 3 2nd September 2005 01:49 PM
Different direct heating styles? ktkammon Tubes / Valves 7 15th March 2005 08:55 PM
Copyright 1999-2017 diyAudio
