Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET - Page 4 - diyAudio
Old 5th September 2006, 09:21 PM   #31
diyAudio Moderator Emeritus
Bas Horneman's Avatar
ECC86
Another added advantage is the low voltage b+ one can use!
planet10 needs your help:
Let's help Ruth and Dave
Old 5th September 2006, 09:22 PM   #32
Fuling is online now Fuling  Sweden
Thanks for shown interest!
The circuit is under evaluation, but initial testings indicates that it is perfectly capable of driving an IRFP260-based follower to 50kHz without loss of gain.
My PSU is not quite up to the task, and either the cathode resistor or the 175R reistor in the CCS must be made adjustable to set the operation point for max linear output swing.
Im definitely going to make something out of this some day when I have the time, there are plenty of more important projects in the pipeline right now.
Old 5th September 2006, 09:24 PM   #33
Direct coupling to the output stage was a major design goal, if I had to use a coupling cap Id definitely choose a more potent tube and skip the White follower.
Old 5th September 2006, 09:43 PM   #34
lineup is offline lineup  Sweden
lineup's Avatar
Yes, this is great advantage for making a preamp for SEWA.
Same thinking as I had, Bas Horneman.
Here is another wellknown HYBRID project:
http://www.customanalogue.com/diytub...lone/index.htm
with the diyaudio topic of:
Tube with Power IC Output Stage - JLTi
This is a Tube preamp + a Chip Amp output power amp
= Hybrid between tube and transistors.
By this diyAudio.com member:
Joe Rasmussen
http://www.diyaudio.com/forums/membe...fo&userid=4828
lineup
Old 5th September 2006, 10:11 PM   #35
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Excuse me fore being a bit ignorant and off topic......
But wouldnt it be posiible to simply use a low noise step-up transformer
Nah, maybe not eneough voltage ...?
Old 5th September 2006, 11:00 PM   #36
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you mean-xformer instead preamp?
then you forgot impedance issues
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th September 2006, 11:51 PM   #37
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default I must agree with BAS a triode with a CCS
Bas Horneman has the right idea, a triode with a CCS on top. I have built this circuit to drive the grid of a 300B, should handle that MOSFET's without any issues.
Old 6th September 2006, 11:56 AM   #38
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Even the capacistanse of the Mosfets?Some say it wont,thats why I decided to go for a CF..
Regards ke
Old 6th September 2006, 12:06 PM   #39
A CCS-loaded 6C45 would have about 1kohm output impedance, which might me a bit high.
The same tube with a 3:1 stepdown transformer on the output would probably be much better suited for the job!
Old 6th September 2006, 12:29 PM   #40
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
What is the problem with 1K out Z?
You'd be bandwith limited to about 600KHz...
Mads K
Power DAC for for SEWA 7 Watt ClassA MOSFET amp Tyimo Digital Source 4 28th November 2006 12:40 PM
Copyright 1999-2017 diyAudio
