Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET - Page 28 - diyAudio
Old 1st June 2009, 07:50 AM   #271
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by Tyimo
Hi Lineup!
Here is:
http://www.diyaudio.com/forums/showt...82#post1173182
but it is 15W!
Now I use a 30W version...
greets:
Tyimo
Here is my choke loaded 30W amp:
P.S.How can I put more picture in one post?!?
Thanks very much, Tyimo.
You are a true friend.
Nice pictures. I have a look at svhematic and download it now.
See you
lineup
Old 1st June 2009, 09:15 AM   #272
Tyimo is offline Tyimo  Hungary
You are wellcome anytime my friend!
Nice pictures.
Unfortunately, not. Made by a mobil phone cam. I will try to make a better one.
Tyimo
Old 1st June 2009, 09:45 AM   #273
Geek's Avatar
Hi Tyimo,
You can't
My heatsink is the same cm^2 as your first one about and the same schematic.
Iq is correct, I wonder why it cooks?
Dang sand!!!
Cheers!
Old 1st June 2009, 12:19 PM   #274
Hi Geek!
My first pics is the original SEWA with CCS and 30Vdc.
The heatshinks are ca. 50C., but my whole case is made from 5mm aluminium. So the case itself a big heatsinks.
Do you have some oscillations??
Tyimo
Old 2nd June 2009, 02:03 AM   #275
Geek's Avatar
Hi Tyimo,
Hi Geek!
Tyimo
No oscillations, but didn't take into account the case. That would likely do the trick.
I just need a bigger sink then, because I was going to make the SEWA into a piece of furniture with hardwood fretwork and little exposed metal
Cheers!
Old 2nd June 2009, 05:12 AM   #276
Hi Geek!
I think that will be the solution.
Greets:
Tyimo
Old 2nd June 2009, 05:33 AM   #277
meanman1964's Avatar
Hi Tyimo,
Do you have a schematic of the 30Watts version?
Old 2nd June 2009, 02:40 PM   #278
Hi meanman1964!
First you have to finish your tubepre and Choke loaded amp and write here your listening impressions.
After we can speak about it...
Greets:
Tyimo
Old 2nd June 2009, 04:44 PM   #279
Yes, I know
Power DAC for for SEWA 7 Watt ClassA MOSFET amp Tyimo Digital Source 4 28th November 2006 12:40 PM
Copyright 1999-2017 diyAudio
