Tube Pre Amplifier for SEWA 7 Watt ClassA MOSFET - Page 16 - diyAudio
Old 17th October 2006, 08:15 PM   #151
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally posted by Ryssen
I think thatīs the case,already tried with 1,2v bias the trafo canīt keep up the voltage..Gonna try this bigger trafo I ordered.
But don't expect significant quality improvement.
To charge a capacitance of 1 Farad during 1 Second to 1 volt we need 1 Ampere (I love the Metric system!).
Suppose, your FET has 3000 pF input capacitance. Suppose, you have about 0.5 voltage swing s-g to fight against the capacitance (actually much less).
Minimal current is 2*(10^4)*2*3(10^-9)0.5=6*(10^-5) Amperes, i.e. 0.01 mA. If you have 10 Ma, it means you have 1000 times more, or you have already enough current for a swing 500V s-g.
It means, neither CD, nor MP3 can give you such a quality signal so you can measure differences on the high end of your band.
The Devil is not so terrible as his math model is!
Old 17th October 2006, 08:36 PM   #152
Wavebourn's Avatar
Oops...
Sorry for the mistake, I've lost "6", anyway you have almost nothing to gain by a bigger current. It is better to play with the current for less triode distortions and forget about partially capacitive input of your FET follower.
Use your new tranny for your new project.
Old 17th October 2006, 09:13 PM   #153
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Well,Iīve heard some say the 6C45 "needs" at least 30mA to sound itīs best,so who knows.
Regards Åke
Old 17th October 2006, 10:39 PM   #154
Shoog's Avatar
Try your bigger transformer.
Did you say you were using the transformer back to back with your main power transformer. If so then this setup has particularly poor regulation.
Shoog
Old 17th October 2006, 11:00 PM   #155
Wavebourn's Avatar
They were right. Better use another tube.
Old 18th October 2006, 02:03 PM   #156
Ryssen's Avatar
No,no not another tube I will fix this..
Sounded pretty good at 15mA to.
Regards Åke
Old 19th October 2006, 12:26 AM   #157
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default CCS with 6C45
I think you need to raise b+ to about 220V and lower the resistance on the CCS (10E in Series w/470E) and you should be on your way. As far as an LED goes, I can't help you much there. I think you got it right that you are too low a voltage on the CCS that feeds the tube, THe 6C45 sounds fine to me at 18-20mA, but it will handle more current if that is your wish.
Old 19th October 2006, 03:27 PM   #158
Wavebourn's Avatar
I'd use 175V/30 MA with 250V B+
Old 19th October 2006, 03:41 PM   #159
Ryssen's Avatar
The new bigger one,lets hope it can keep up the power..
Regards Åke
Old 28th October 2006, 08:50 AM   #160
Tyimo is offline Tyimo  Hungary
Default BOZ PSU for tubepreamp
Hi!
Is it possible to modificate the BOZ PSU (Mads version) to 120-150V??
I know I need to change the zeners, but what about the rest of the parts??
I would like to use it for my tube pream.
Greets:
Tyimo
Power DAC for for SEWA 7 Watt ClassA MOSFET amp Tyimo Digital Source 4 28th November 2006 12:40 PM
Copyright Đ1999-2017 diyAudio
