diyAudio Sponsor
Old 4th September 2006, 11:37 AM   #1
cs is offline cs  United Kingdom
Default EL84 in ultra-linear mode
Does anyone have IV curves for the EL84 in ultra-linear mode (standard 43% taps) ?
I have only been able to find curves for pentode and triode mode.
Old 4th September 2006, 11:39 AM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Here:
http://www.tubes.mynetcologne.de/roe..._40ul_300v.pdf
Old 4th September 2006, 12:42 PM   #3
Great.
Many thanks
Old 4th September 2006, 09:35 PM   #4
edl is offline edl  Hungary
edl's Avatar
One more...
With more informations...
http://frank.pocnet.net/sheets/129/e/EL84.pdf
Old 6th September 2006, 11:12 PM   #5
Whew!
That should satisfy you, CS! I have set the printer churning, since much of this that I had years ago went the way of al - er - books. My thanks to Giaime and Edl also.
Just an extra small point; I have a single graph illustrating that optimal conditions for fixed and cathode bias are not the same for minimum distortion; different load impedance as well as bias. Unfortunately I am not at home at present, and will only be able to post this by end of week. I have not studied the above data; it might be that you can work that out from these two sources.
Old 7th September 2006, 10:40 AM   #6
diyAudio Moderator Emeritus
ray_moth's Avatar
Johan, nice to read one of your posts again. Welcome back! How are you now?
Old 7th September 2006, 11:00 AM   #7
Giaime's Avatar
Nice to read you Johan!!!
Old 10th September 2006, 11:00 AM   #8
Hi Ray_Moth, Giaime,
Thanks for concern. Physically almost OK, but still staying with my son. Will have to move back to my home shortly; psychological issues will have to be dealt with. Reading and contributing to this site help considerably in that respect!
Old 21st September 2006, 03:50 PM   #9
Ray_Moth,
Sorry man, never replied. My injuries (broken ribs) have healed well and otherwise everybody (including my son where I still stay) are looking after me admirably.
The trauma of a lost spouse will be there forever, but life must go on. Taking part here is also a definite cure.
Thanks.
EL84/6BQ5 Ultra-Linear Push-Pull Recomendation diegot Tubes / Valves 17 5th April 2007 11:41 AM
Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? vinyvamos Tubes / Valves 1 28th January 2006 04:07 PM
el84 ultra linear datat sheet quirkydreamer Tubes / Valves 1 18th February 2005 10:42 PM
EL 34 30W ultra linear GAK Tubes / Valves 70 24th November 2004 11:57 AM
Page generated in 0.10306 seconds (78.61% PHP - 21.39% MySQL) with 10 queries
