| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#2 |
wrangler,
Your last 2 regulators are referenced from: R19 / R28 then a RC including R21 / C37 provides a slow turn-on So you'll have to change R28... You have to be sure the voltage on Q7/Q8 is 20 to 30 volts higher, about 330/340 volts if not ... To do so measure the voltage at the connection of R19/R21. R19 + R28= 1.5 MOhms current = 340 V/ 1.5M = 0.226 mA Voltage ref = 0.226 mA * 1MOhms = 226 Volts New value = 305 Volts ==> i= 0.309mA ==> R19 = 100 KOhms ======> That changes the output voltage on both Q7/Q8 Then if you want to change only the output voltage on Q7 you have to put a voltage divider with 100K / 1M Ohms and a RC just before R25. Alain. |
#3 | |
| Thread Tools | |
| Using Battery for 300v B+ ? | mark02131 | Tubes / Valves | 14 | 6th March 2009 08:41 AM |
| Using Horizontal Output Tubes - Power Supply | gingertube | Tubes / Valves | 8 | 29th September 2008 07:50 PM |
| stereo push pull amp one heater supply for power tubes | nhuwar | Tubes / Valves | 5 | 3rd February 2007 03:32 AM |
| SS No R No C Power Supply for Tubes | Audio_idiot | Tubes / Valves | 1 | 26th September 2006 09:36 AM |
| Use tubes for 2000V. power supply, | extremy | Tubes / Valves | 1 | 17th April 2004 04:55 PM |
| Page generated in 0.13871288 seconds (73.91% PHP - 26.09% MySQL) with 11 queries |
