diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   ripple values in B+ supply (http://www.diyaudio.com/forums/tubes-valves/85814-ripple-values-b-supply.html)
Antonio Tucci 2nd September 2006 10:11 PM
In a 2-stage 2A3 amplifier (6C45P-2A3) which should be the values of ripple in the B+ supply of the first and second stage ?
Klimon 2nd September 2006 11:03 PM
About 70mV max. for the output stage (30 or less being very good), 10mV for the input stage (3 or less being very good), other people might have other standards...:D Edit: that's my baseline for two-stage single-ended IDHT, dunno what's the drill with DHTs.
Simon
sorenj07 2nd September 2006 11:58 PM
basically run a bunch of sims in psudii with real-world chokes and caps etc. and build the best one you can afford/have room for.
AndreasS 3rd September 2006 09:53 AM
Re: ripple values in B+ supply
Best answer:
http://www.audioasylum.com/forums/se...ges/47106.html
regards Andreas
Copyright 1999-2017 diyAudio
